Planars & Exotics ESL's, planars, and alternative technologies
Wiring a Planar
Wiring a Planar
Old 10th December 2019, 11:18 AM   #21
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Originally Posted by bolserst View Post
I believe the general arrangement is as you suspect. The patent application by the designer appears to mainly deal with details of construction, in particular stability of diaphragm tension while using thinner metal frame. But, I am basing that on the provided online English translation which may not be exact. Both attached...
FWIW, I heard them at RMAF last year and they were one of the few rooms I went back to multiple times to hear different types of music. Mids and highs were lovely with surprising amount of heft and definition in the bass range.
thanks,for the read material
Looks like almost a copy of the magnepan pictures in there older patents must be a patent thing to draw exactly the same. even the bended steel has been done in the first magnepans, in the 70's , and later in b&g patents to. but i guess not so much easy to make the same every time
Old 10th December 2019, 02:34 PM   #22
RogerGustavsson is offline RogerGustavsson  Sweden
The Winey/Magnepan and Croft/Graebener/BG patents are old now. Did/do they apply to Europe?
Old 10th December 2019, 04:07 PM   #23
WrineX's Avatar
not sure but they did do the exact same thing , and as far as i know nothing new here under the sun. just the same old same. not bad i mean there is only so much you can do. but i laugh at the whole technical stories companies come up with , and end up with the exact same stuff
Old 11th December 2019, 01:39 PM   #24
lowmass is offline lowmass  United States
very rare for there to be anything truly "new" in loudspeaker design
most patents are just a lot of construction detail, not necessarily any new discovery
Wiring a PlanarHide this!Advertise here!
Wiring Help: 4 Ohm 12" + Two 4 Ohm Planar Tweeters sarsicism Multi-Way 25 5th September 2019 03:56 AM
Wiring a line array: altering wiring schemes for matching levels w/woofer dave251 Multi-Way 6 5th February 2014 02:21 AM
New BG planar mid.. ScottG Multi-Way 1 6th February 2006 08:50 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 03:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
