Planars & Exotics ESL's, planars, and alternative technologies
Back to back electrostatic speakers
Old 20th September 2019, 01:24 AM   #11
tnargs is offline tnargs  Australia
Default It's a pressure source
Hi, from my limited understanding:-
Originally Posted by jimmyjazz View Post
I am familiar with the manner in which a standard dipole suffers in the low end when placed too close to a wall -- the out of phase rear wave largely cancels with the front wave when the reflected path length is small relative to a wavelength.
It's not the wall causing this, it's the rear wave wrapping around the speaker frame and cancelling the front wave.
In fact, when the anti phase rear wave bounces off the rear wall, it reverses phase and becomes in phase. In which case the closer to the rear wall the better! So that is not why the speaker is kept away from the wall: it is an attempt to increase the delay, so the rear sound is perceived as more distinct and not a blur-causing part of the front wave direct energy -- and is more beneficial in the mid and high frequencies than the bass.
DSP can mitigate this, I suppose within amplifier and driver limits.
Driver limits at low frequencies are so severe for electrostatic panels that it would be IMO unwise to try using DSP for this purpose.
If one were to try to create a "bipole" by using a pair of electrostatic loudspeakers placed back to back and wired in phase to a mono source, would the bass response suffer even further? It feels like even though the panels are flexing away from each other, which is in some ways similar to a bipole loudspeaker, the fact that the back waves aren't trapped in a sealed box would create a mess in the room. I'd love to try it out, but I have no access to any planar loudspeakers. I would think electrostats would be the worst candidate because of the relative transparency of each membrane to impinging sound.
Have any of you tried this? Any links/papers/reviews?
ESL membranes are pressure sources and don't respond well to pressure on the back of the membrane, whether it be (imperfect) absorbent material, cabinet walls, or another membrane producing the pressure. They are quite different from dynamic drivers and cannot be treated in similar ways.
I don't recommend your approach at all.
cheers
Old 20th September 2019, 01:52 AM   #12
jimmyjazz is offline jimmyjazz  United States
This is counter-intuitive. If it were true, then a dipole's bass response would not get worse as the speaker is placed closer to the wall, which is in fact what happens. (I'm not suggesting that there is no effect such as you describe, but merely that it doesn't tell the whole story.)
Nope. The pressure doubles at the wall and the reflected wave comes off the wall in phase with the impinging wave. You are describing a pressure-release boundary condition, more akin to sound exiting a duct, but focused on that which reflects off the opening back upstream.
Old 20th September 2019, 02:34 AM   #13
ticknpop is offline ticknpop  Canada
The Martin Logan CLX uses back to back bass panels.
Old 20th September 2019, 05:11 AM   #14
It's the fundamental principle of dipole radiation. It is the source of the figure-8 pattern.
Quite right, I was thinking of sound in walls and cabinets. Confused myself.
Doesn't change the real reason why dipoles are kept away from walls, though, as I mentioned.
"....the (dipole) loudspeakers must be placed at some minimum distance from those large surfaces in order to delay specular reflections by more than 6 ms. This allows the brain to give primary attention to the earlier arriving direct sound...." Sigfried Linkwitz
Thanks for giving my comments some thought. The concept remains a bad idea, IMHO.
cheers
Old 20th September 2019, 05:25 AM   #15
[INDENT] "....the (dipole) loudspeakers must be placed at some minimum distance from those large surfaces in order to delay specular reflections by more than 6 ms. This allows the brain to give primary attention to the earlier arriving direct sound...."
That quote is not limited to dipole loudspeakers. You added "(dipole)" but Linkwitz made no such limiting claim.
Old 20th September 2019, 08:13 AM   #16
I added it to be sure that no-one thinks it doesn't apply to dipoles. He wrote it on a page dedicated to a full-range dipole speaker, and hence that is his reason for wanting those dipoles that far from the rear wall.
I commend you to take on his thinking.
cheers
Old 20th September 2019, 12:29 PM   #17
OK, we're going in circles. The topic of this thread is not about speaker placement. It's about trying to mitigate low frequency cancellations that are characteristic of dipoles in real rooms. I don't own dipoles, and if I did, I wouldn't jam them up against a wall.
Old 21st September 2019, 09:32 PM   #18
golfnut is offline golfnut  New Zealand
golfnut's Avatar
You can get some insights into the effects of walls by imagining that the walls are mirrors. So, supposing that your speakers are a few metres apart and have a wall say 1 metre behind them. What you hear will be affected by the images of your speakers, a metre beyond the wall with their rear facing you.
We can draw the following conclusions
First, if a dipole speaker and its image are very close and back-to back, there will be a lot of cancellation and loss of bass.
Second, if there is a gap between the speaker and its image, then they will be in phase at some frequencies and out of phase at others, resulting in a comb-filter like frequency response with ripples. The peaks occur every c/2x, where c = is speed of sound, x = distance speaker is placed from the wall. For speakers 1 metre from the wall, the peaks occur every 170 Hz.
Third, you can exploit the figure-eight polar response of a dipole to lessen the cancelation effects by having the speakers toed in. If the planar speakers are placed at 45 degrees to the wall, the cancellation/reinforcement effects are minimized.
Fourth, distance helps, not only because of the delay and psychoacoustics, but also because speakers further away sound quieter, so the degree of cancelation/reinforcement will be less.
Fifth, you can reduce the reflection by putting absorbing material on the wall. Impossible at low frequencies but effective in the vocal range where your ears are most sensitive.
Sixth, when you start including reflections from the floor, ceiling and other walls, its all a mess, but in general, avoid corners. Floor-to-ceiling line-source speakers are less complicated , and tend to suffer less from corner effects.
So, my ESLs are about a metre from the walls, toed in, and have curtains behind them. The bass response is noticeably improved if I pull them further out from the wall but she who must be obeyed objects.
“Nothing is more practical than a good theory.”
– Ludwig Boltzmann
Old 21st September 2019, 11:42 PM   #19
I agree 100%, golfnut. My acoustics prof in grad school used "image sources" as much as he could, regardless of the problem. It often simplifies the problem immensely.
Back to back electrostatic speakersHide this!Advertise here!
Possible to place speakers back to back in a ported enclosure? Buzzyll Subwoofers 3 3rd August 2016 05:15 PM
Back to back speakers? chico1st Full Range 20 5th February 2015 03:49 PM
Half bridge tube smps 2.sec.transf. back to back ? ? papasteack Power Supplies 2 1st August 2014 10:34 PM
Dipole idea: mount midrange drivers back to back without baffle OllBoll Multi-Way 44 24th October 2012 11:31 PM
(Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions paulspencer Multi-Way 9 15th August 2004 05:34 AM
Copyright ©1999-2019 diyAudio
