Planars & Exotics ESL's, planars, and alternative technologies
Have to fix my Quad ESL 57
Old 7th September 2019, 10:04 AM   #41
johnsurnamerobinson is offline johnsurnamerobinson
I really dont know what much else to say.You purchased something off of Ebay (unseen,no waranty) its pot luck !!!.That does NOT make you an idiot.Millions of people take a punt on Ebay.some you win/lose. Keep at it.You will end up with some nice speakers. Best regards
Old 7th September 2019, 10:24 AM   #42
RE:Panels.
Quads need a high resistance diaphram to prevent 2nd harmonic distortion. IF !!! the holes are SMALL you might ???? be able to simply patch them and leave it at that.
Old 7th September 2019, 11:53 AM   #43
legopart is offline legopart
legopart's Avatar
I not bough it from EBAY, I bought it from my country, self pickup, but I compare it to Ebay prices and not have enough knowledge about it!
to that point I only tried to restore some Electrostatic headphones and Fail!!! (they sound bad!, because of bad glue and bad stretch)
but I got lots of knowledge from this trying.
to this moment I finish to read lots of books and guides about ESL speakers and quad esl 57
so I want to try again and fix this issue.
I tried a lot! and even bought the kit from ERaudio and the guide to do so.
The only thing that upset me now is the time that i spend, the money and the materials that I still need and searching for.
RE:Panels.
I gonna open the stators,
I sure that one of them is born a bit with hole
look at the bottom of treble panel when there is RTV (Silicon) used
I goind to strech another membrane,
but before that I have to fix this hole and make the area as new.
I plan to use this type of epoxy stick to fix the surface
then I will coat it with conductive paint and color it
and after all I will stretch the membrane from the kit that I bought
Old 7th September 2019, 04:44 PM   #44
lcsaszar is offline lcsaszar  Hungary
I wouldn't attempt to repair the diagphragm on my own. I just replaced the dust covers on my units, and that was just up to my skill (12 um for the bass, 6 um for the treble, perhaps a bit too thick: 6 and 3 would be better). For replacing the diaphragm you'd need a tool for stretching, some special high resistance conductive coating paint, etc. Not an easy task at all, and I didn't dare to do it myself.
The replacement treble units I ordered directly from the manufacturer:
ESL | QUAD | the closest approach to the original sound
Service | QUAD | the closest approach to the original sound
Old 7th September 2019, 04:58 PM   #45
mattstat is offline mattstat
It looks like some of the siliconed areas may only be covering spots where minor arcing was occurring. Those should be easier fixes, as long as you are careful when removing the silicone.
If you have smaller areas of damage to the stator structure, you could just clean/insulate them, and ignore them if full repairs prove too difficult. As a percentage of the total stator area, they seem to be small. 20*log(new area/original area) will give you the loss in decibels for the decreased area. A 10% loss of driven area is only about 1 dB.
If you are still looking for conductive paints, this page suggests using car defogger repair paint. Maybe that's easier to come by in your area. I don't remember if this link was referenced earlier in the thread.
Quad ESL-57 repair by Hey You
Old 7th September 2019, 06:29 PM   #46
The edges of the panels will be much less sensitive to coating resistance than the centre so easier to repair.All you need to make sure is small holes dont run into a huge gash!!!!!
If Quad are still servicing these speakers you should consider replacing the panels,as and when you can afford it.THEN look after them.The should give good service for a lifetime if not overdriven.
Old 7th September 2019, 06:43 PM   #47
legopart's Avatar
cant find there any information about conductive paint that I searching for.
Thanks!
I found lots of guides and images on the internet and books and learn a lots of things.
this site contains more info then I cant obtain
here only the faqs section
The Quad ESL - FAQs
or hard maths that I will never understand
Hard Core
I have to set and order the deficient materials, and preper to work on this speakers
Unfortunately I tight to much the limit with the capacitors...
For EHT If there is enough space on the board I will buy some WIMA MKP10
But if so I decide to use Polypropylene one with only 2kV and not 2.5kV as other guide reccomended
*Stax amps using this type of capacitors for EHT boards
The other option is to keep the original one and replace only the diodes
CBB Metallized Polypropylene Capacitors 2000V 2kV 102J 103J 104J 474J 105J etc. | eBay
and for the sound I decided to use something like 4kV in series
2 in series (1100pF 2kV*2) and 4 in series (550pF 2kV*4)
I think that the price is too high to restore it or order another from quad.
in addition I afraid that the bass panels will needs to restore on the future
Old 7th September 2019, 06:53 PM   #48
Regarding diaphrams in general.Problems in making properly working electrostatic diaphrams have been a regular on this site for years.And the few that have managed it are coy with their methods.
Peter Walker was a genius to do it back in the 1950s
Old 7th September 2019, 07:00 PM   #49
Paper caps are `self healing` and would have been original
Previous owners must have really butchered these poor speakers.
Last edited by johnsurnamerobinson; 7th September 2019 at 07:05 PM. Reason: addition
Old 7th September 2019, 10:24 PM   #50
legopart's Avatar
Wow, my curiosity took me lots of time ...
I disassembled this panel at the first time
I had to disassemble some good one for first time
Used the most bad method... the cutters (that one pair Brock and almost punched through my eye) [I wore a safety glasses for this work ]
The sellotape on the frame destroyed all the paint
This board bend too much
This after dissasamly
Front
Back
The diaphragm still glued good but still I deside to restore it as well as new.
This RTV made my exhausted.
but the pivots made my even more... have to find some better method.
and the sellotape, maybe I have to heat it first.
LITTLE FIXING
this is not RTV, this is hot glue
Have to fix my Quad ESL 57Hide this!Advertise here!
What Quad Colorado do I need: Quad 303 power amp XsamuraiX Solid State 4 11th October 2018 04:17 PM
(20) NSC/FSC MM74C00N DIP-14 Quad 2-Input NAND Gate . Quad Jimmy154 Swap Meet 0 4th May 2018 02:26 PM
RARE QUAD ESL57 ORIGINAL QUAD UK TREBLE PANELS - PAIR lampes Swap Meet 3 6th December 2012 09:02 PM
WTB: Any Quad II or Quad 22 units- working or not or parts for them hatrack71 Swap Meet 3 29th August 2010 02:46 PM
FS: Ei/Yugo KT90 quad, 6H30, svet KT88 quad - melbourne avian Swap Meet 9 15th April 2010 06:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
