Planars & Exotics ESL's, planars, and alternative technologies
Have to fix my Quad ESL 57
Old 15th October 2019, 02:32 AM   #121
legopart is offline legopart
legopart's Avatar
First look
Old 15th October 2019, 10:45 AM   #122
legopart's Avatar
Find another theoretical problem...
The distance between the pins is actually high because there is a top/high level voltage there.
And my capacitors legs that connected over the air made the distance shorter by half.
Though about: put some hot glue, hit shrink tube or silicone between the elements, to avoid arcs.
do silicon is ok for isulation?
Old 15th October 2019, 07:48 PM   #123
legopart's Avatar
Have to clean the floor now
do only basic cheap paint
Broke one resistor.
its made of coal
Old 16th October 2019, 07:44 PM   #124
legopart's Avatar
Found this type of fuse before tweeters,
in parallel to this fuse connected 50ohm
What do you think about trying this method?
Still have this cheap types, (the coil is: with core 4.0mH and without 1.0mH) =D
60W Speakers 2 Way Audio Frequency Divider Loudspeaker 2 Unit Crossover Filters | eBayClick the image to open in full size.
Some crossover boards using real glass fuse
really forgot about the crossover methods.
Can some one help me please.
Which fuse to use on this board phase (+)
the (-) will get 2.2ohm 10W additional capacitor.
Old 17th October 2019, 05:19 PM   #125
legopart's Avatar
Lost my camera memory card
so only phone photos
and copy past the second side.
matched capacitors/resistors choose, replace the solder with Cardars
recoate EHT
Spent must of the dielectric spray (that for the panels I found it useless)
on the transformer
re soldered and still not finish, need to mess with EHT and put some fuse one the phase.
I will use only my required voltage (240v) and isolate the rest
I plan to use 30mA fuse on the entering level. if it will blow then I will use 1A
Old 17th October 2019, 05:27 PM   #126
tschrama is offline tschrama  Netherlands
keep up the good work
Servicing guitar and Bass amp, giving amp building workshops at my small atelier www.sgravenmade.com
Old 17th October 2019, 06:11 PM   #127
clog is offline clog  Netherlands
In my opnion this is a very brave attempt to repair the (almost) unrepairable. I wish you lots of success !
Old 22nd October 2019, 04:24 PM   #128
Nemeske is offline Nemeske  Hungary
Nemeske's Avatar
I subscribed to your topic!
If I might suggest, you should buy a pair of panels those salvaged from a working speaker, maybe this one.
This seller usually put up some QUAD panels and parts for sale for reasonable price. If you are lucky (as I were) you can score some undamaged treble panels from OTA for dirt cheap.
Old 24th October 2019, 04:20 AM   #129
legopart's Avatar
thank you all!
Still wait for the materials.
decide to put the protecting board outside, drill and clean the copper parts
Plan to buy new balts, at this point I cleaned the mount and the bolts
the front cover cracked on the begining points, have to find some way to glue it before all of it will damaged
wood is sliced everywhere
every part is full of dust
front cover having some stain
one leg is cracked, and bad glued
washed and started to glue it with quality wood-glue
Old 25th October 2019, 01:26 AM   #130
stokessd is offline stokessd  United States
stokessd's Avatar
Just a note, those bolts aren't metric, they are British Association Thread.
Sheldon
Have to fix my Quad ESL 57Hide this!Advertise here!
What Quad Colorado do I need: Quad 303 power amp XsamuraiX Solid State 4 11th October 2018 04:17 PM
(20) NSC/FSC MM74C00N DIP-14 Quad 2-Input NAND Gate . Quad Jimmy154 Swap Meet 0 4th May 2018 02:26 PM
RARE QUAD ESL57 ORIGINAL QUAD UK TREBLE PANELS - PAIR lampes Swap Meet 3 6th December 2012 09:02 PM
WTB: Any Quad II or Quad 22 units- working or not or parts for them hatrack71 Swap Meet 3 29th August 2010 02:46 PM
FS: Ei/Yugo KT90 quad, 6H30, svet KT88 quad - melbourne avian Swap Meet 9 15th April 2010 06:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
