Planars & Exotics ESL's, planars, and alternative technologies
Quad 63 (and later) Delay Line Inductors
Thread Tools
Old 3rd July 2021, 02:50 AM   #421
bolserst is offline bolserst  United States
bolserst's Avatar
@jan.didden,
Congrats on getting your DD amp up and running!
Looking forward to whatever details you can share about the circuit once you have all the bugs ironed out.
Originally Posted by jan.didden View Post
is that natural rolloff caused by the xformers and xover parts?
No, the natural rolloff is due to the under-damped 2nd order HP mechanical response created by the diaphragm resonance. With constant drive from the amplifier(or amplifier + transformer), the diaphragm excursion will not increase below resonance. (This is similar in concept to a dynamic woofer in sealed box)
If you take a near field measurement you should see a LF response similar to those shown in the attached images in this post: Quad esl resonance damping: how?
Old 3rd July 2021, 02:51 AM   #422
bolserst's Avatar
Yes there seems to be a difference. In this case, I applied the probe EQ after the measurement rather than to the source level, I have to see if that has introduced an error.
Not that this has any bearing on your final results now that you are EQing based on microphone measurements, but just curious if you ever figured out why measurements were different between the setups? One thing I had meant to ask, did you try swapping the connections to the differential probe? Ideally if there is no common mode contamination to the measurement you should get the same response but with opposite phase. I recall having issues with this when I was measuring the response of A SoundLab A-1 interface for different setting of the MID and LF controls. Eventually I had to borrow a Jensen Input transformer to get rid of the problem.
Full Range Electrostatic Question
Old 3rd July 2021, 03:03 AM   #423
bolserst's Avatar
Originally Posted by bolserst View Post
… I plan to wind up some inductors this weekend that more closely match the winding geometry(ie starting from near zero radius) and see if I can get a better estimate of the coupling factors to use.
Originally Posted by Hans Polak View Post
Here is the version when cross-coupling the inductors with K=0.3 for the adjacent and K=0.1 for those one place further.
I did finally get the time to wind up some inductors more similar to the size and proportions of the actual delay-line inductors.
The new measurements show that the original estimate was not too far off.
New coupling factor estimates are:
K=0.25 (adjacent inductors)
K=0.05 (inductors one place further down the line)
Last edited by bolserst; 3rd July 2021 at 03:30 AM. Reason: fix orientation of pic.
Old 3rd July 2021, 06:08 AM   #424
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I never followed that up unfortunately. I did notice that the amplifier I used in the test (a 200W class D) did not have a very flat response when driving the '63, so that may have been a factor.
Jan
Old 3rd July 2021, 06:11 AM   #425
jan.didden's Avatar
@jan.didden,
Thanks, got it.
Jan
Old 5th July 2021, 04:16 PM   #426
Hans Polak is offline Hans Polak  Netherlands
Hi Steve,
Great to have these values confirmed.
I've adjusted the model to these two values, but as expected, it makes very little difference.
Even making the second coupling factor K=0 does very little.
But nonetheless, your figures are exact and the model is updated.
Hans
Old 20th August 2021, 07:45 AM   #427
mkc is offline mkc  Denmark
Hi Jan,
Any progress with the DD drive?
Mogens
Old 20th August 2021, 07:46 AM   #428
jan.didden's Avatar
I did, but then got sidetracked with an upcoming move of my household and my lab. Sometimes life interferes with your plans ...
Jan
Old 20th August 2021, 08:22 AM   #429
Yes, it's not always easy to find time for the fun stuff. I was just curious.
I'm also in the process of rebuilding house. Has taken far longer than it should... oh. well.
Mogens
  Reply to this post
Quad 63 (and later) Delay Line InductorsHide this!Advertise here!
Thread Tools
Quad ESL-63 delay-line capacitors TimA Planars & Exotics 21 29th May 2014 02:01 PM
E. J. Jordan Delay Line assembled Multi-Way 89 15th August 2012 02:54 PM
dual/quad class D inductors? gmarsh Class D 4 1st January 2012 04:19 PM
inductors on the AC line Stefano Pass Labs 7 7th February 2006 12:49 PM
quad esl's delay lines tade Planars & Exotics 13 18th August 2005 06:11 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
