Planars & Exotics ESL's, planars, and alternative technologies
Quad 63 (and later) Delay Line Inductors
Thread Tools
Old 17th June 2021, 04:17 PM   #411
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Yes I saw your posts.
You know, I turn up the variac to get 'only' about +/-1500V for testing, instead of the full +/-2400V.
You really have to be careful not getting the idea that 1500V is much lower and therefor somehow not as dangerous.
Jan
Old 17th June 2021, 04:19 PM   #412
Hans Polak is offline Hans Polak  Netherlands
Here in cyan is the result of an on axis recording at 1 meter distance.
Hans
Old 17th June 2021, 06:05 PM   #413
jan.didden's Avatar
Thanks Hans, I was more concerned with the low end.
I guess I should roll of the low end to prevent excessive excursion of the foil?
Jan
Old 17th June 2021, 08:53 PM   #414
No I don't think you have to roll off anything at LF.
The ESL will do the roll off by itself.
Hans
Old 17th June 2021, 09:12 PM   #415
martin clark is offline martin clark  Europe
Doing so at LF may usefully increase power handling/avoidance of a strike though, overall?
Settling for 40hz, say, vs a DD amp's ability to pin the thing at ELF, simply from a recording transient or similar.
(from an amateur just watching this with interest ...)
Old 18th June 2021, 03:42 AM   #416
1audio is offline 1audio  United States
For years I have used a 6 dB roll off for 63s. Always with a sub. If you look at the typical power distribution for music.( except hip hop) it's centered around 100 Hz. Removing the bass demands can significantly increase the max output. Also the panels have a resonance around 80 Hz as I remember that would be good to avoid.
Demian Martin
Product Design Services
Old 18th June 2021, 03:43 AM   #417
Roll off at 100 Hz. Needs a good sub.
Demian Martin
Old 18th June 2021, 06:40 AM   #418
jan.didden's Avatar
That was my thinking.
@Hans: is that natural rolloff caused by the xformers and xover parts? I will not go through that of course.
Jan
Old 18th June 2021, 10:15 AM   #419
Jan,
In the sim the transformers and xovers do not roll off until very, very low and they do not harm anything at all.
This must be very close to the real thing IMO.
Hans
Old 18th June 2021, 10:21 AM   #420
jan.didden's Avatar
OK, thanks!
Jan
Quad 63 (and later) Delay Line InductorsHide this!Advertise here!
Thread Tools
Quad ESL-63 delay-line capacitors TimA Planars & Exotics 21 29th May 2014 02:01 PM
E. J. Jordan Delay Line assembled Multi-Way 89 15th August 2012 02:54 PM
dual/quad class D inductors? gmarsh Class D 4 1st January 2012 04:19 PM
inductors on the AC line Stefano Pass Labs 7 7th February 2006 12:49 PM
quad esl's delay lines tade Planars & Exotics 13 18th August 2005 06:11 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
