Planars & Exotics ESL's, planars, and alternative technologies
Quad 63 (and later) Delay Line Inductors
Thread Tools
Old 7th June 2021, 01:37 PM   #391
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
But you more than 3mA to drive the panels, and a resistor would mess up the freq response with the capacitive load part.
Jan
Old 8th June 2021, 09:56 AM   #392
Hans Polak is offline Hans Polak  Netherlands
3mA at 2500V means 7.5Watt.
Probably enough to be lethal, especially with Janís superconductive shoulders.
Hans
Old 8th June 2021, 10:07 AM   #393
Lampie519 is offline Lampie519  Netherlands
Lampie519's Avatar
What do you prefer?
Old 8th June 2021, 02:33 PM   #394
mattstat is online now mattstat  United States
Watts aren't the typical unit of concern when it comes to electrocution. Current is where the action is. Impedance of the body and voltage, of course, influence the amount of current flowing through you, but a focus on simple watts isn't one that's going to provide the best prediction of lethality.
This link gives a basic rundown of the typical hazard ranges
Electric Shock Hazards
Old 8th June 2021, 03:09 PM   #395
esl 63 is offline esl 63  Sweden
If you mean 2500V on ONE plate the power output is 4 times that = 30 watt. So 3mA in one plate is in the ballpark. It is also considered "safe".
Hans
Old 8th June 2021, 04:14 PM   #396
jan.didden's Avatar
Two times. Double the voltage at the same current is 2 x power. But it is separate anyway, you either touch one panel or the other, both at the same time is physically very hard, so its 2500V @ 3mA in your suggestion.
But anyway, as I explained above, 3mA limit is not feasible.
Jan
Old 8th June 2021, 04:16 PM   #397
P=U^2/R
Old 8th June 2021, 04:28 PM   #398
MarcelvdG is offline MarcelvdG  Netherlands
2500 V peak per stator is 5 kV peak differential
The impedance plots earlier in this thread show magnitudes of the order of 400 kohm
5 kV/400 kohm = 12.5 mA, so if there were a current limiter in the amplifier, it would have to be set to at least 12.5 mA
If you want to use a series resistor as current limiter, you would presumably want its impedance to be much smaller than that of the loudspeaker, so most of the 2.5 kV peak ends up in the loudspeaker and not across the current limiting resistors.
Accepting 10 % voltage loss, you can allow resistors of 22 kohm per stator, resulting in a perfectly lethal Norton current of just over 110 mA.
Where on Earth does that 3 mA come from?
Old 8th June 2021, 04:29 PM   #399
jan.didden's Avatar
P=U^2/R is not applicable here; I is constant, V varies.
P = I x V; 2 x V same I is 2 x power. Do we have to spend time on that here??
Jan
Old 8th June 2021, 04:29 PM   #400
jan.didden's Avatar
Just a random number I guess.
My design is for 12mA peak current. Should be just sufficient.
Jan
Quad 63 (and later) Delay Line InductorsHide this!Advertise here!
Thread Tools
Quad ESL-63 delay-line capacitors TimA Planars & Exotics 21 29th May 2014 02:01 PM
E. J. Jordan Delay Line assembled Multi-Way 89 15th August 2012 02:54 PM
dual/quad class D inductors? gmarsh Class D 4 1st January 2012 04:19 PM
inductors on the AC line Stefano Pass Labs 7 7th February 2006 12:49 PM
quad esl's delay lines tade Planars & Exotics 13 18th August 2005 06:11 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
