Planars & Exotics ESL's, planars, and alternative technologies
Do you believe?
Do you believe?
Old 2nd November 2018, 03:53 AM   #1
lowmass is online now lowmass  United States
Default Do you believe?
Some have expressed interest, but to be honest I just want to show off a bit. Further investigation into why the Dynaplane ribbon is capable of lower distortion than typical free swinging ribbons of same size has resulted in a refinement of the design.
Kinda excited about this....
The following distortion tests were all done in same setup within about an hour of each other. All with crossover around 1 Khz and mic at 1 meter, all at 100 db at around the 2Khz reference region.
First chart (for comparison purpose) is the Fountek Neo 2 . Typical ribbon showing 3rd harmonic on top and hovering around a rather high 3%
2nd chart shows Dynaplane ribbon of similar size to the Fountek yet showing 2nd harmonic now on top and at 100 dB its only about 0.7 %
3rd chart shows same Dynaplane ribbon but with wave guide. Again 2nd harmonic on top and now averaging below .5%. An order of magnitude less than is typical for other free swinging ribbons this size.
To be fair the Fountek is not designed to be used to 1Khz and yes it did give up the gost after a few slow sine sweeps at 100 dB. It was used simply as an example of the typically higher distortions of similar ribbon designs.
While the importance of certain distortion profiles and levels will likely be debated, I am simply excited that after many years of work I have come to a design that both reduces small ribbon distortion by an order of magnitude, AND provides a means of excursion control allowing reliable operation to lower frequency's.
File Type: jpg 15mm sides neo35 2 row .34mm cor .7% 100db.jpg (98.9 KB, 359 views)
File Type: jpg 15mm sides neo35 2 row .34mm cor .5-.2 horn 100db.jpg (101.7 KB, 353 views)
Old 2nd November 2018, 04:53 AM   #2
BTW here is the ribbon at 90 dB ( no wave guide) with 2nd harmonic down around 0.2 %.
File Type: jpg 15mm sides neo35 2 row .34mm cor .2% 90 db.jpg (96.2 KB, 341 views)
Old 3rd November 2018, 02:55 AM   #3
Few is offline Few  United States
Intrigued! Looks promising!
Old 3rd November 2018, 01:43 PM   #4
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Looks nice !!!,Wonder how it looks
But i am not so sure about neos being 3% typically ? cant imagine.
maybe at 100dB ? the datasheet states a 3 order crossover at 2.5khz so yeah it does not like 1khz ... puting 20dB+ to many in there at that freq when you calculate that back to power... hmm poor ribbon
i was busy with some planar tweeters (dont mind the dip that is gone be my next post since i cant find it )
but that already plays from 1khz to what i can measure distortion/frequency under 0.24 % total harmonic, while the 2e is under 0.24% and third orde under 0.06% cant imagine the ribbon would do 3%
Old 3rd November 2018, 02:36 PM   #5
I would love to talk about that BUT at the moment a patent is in the works . All I can say is that it deals with a fundamental issue with free swinging ribbons.
You are right. The Neo2 is much less than 3% at lower volumes. This comparison was done to show what happens to that low distortion figure in typical "free swing ribbons" when the volume goes up, And to provide some sort of reference for the overall test. As well the 100db test still shows this 3% distortion level well past 3 khz so despite the perf below that being outside recommended use the stuff above 3 k is still useful
Yes it was done at 100db.Almost any ribbon will show nice distortion at lower volume.
i was busy with some planar tweeters (dont mind the dip that is gone be my next post since i cant find it ) but that already plays from 1khz to what i can measure distortion/frequency under 0.24 % total harmonic, while the 2e is under 0.24% and third orde under 0.06% cant imagine the ribbon would do 3%
Yes that's sound right. All planers I have measured show lower distortion than typical free swinging ribbons ( of similar size) when the volume goes up. The Planers do not suffer the same issue as a free swinging ribbon.
Its also important to notice that in the typical free swing ribbon as shown in the Neo 2 will have the 3rd harmonic ABOVE the 2nd harmonic at these higher volumes. With the Dynaplane ribbon that is switch around to what you typically see with planers and domes. You probably wont see other ribbon makers posting this fact
The problem I see with planers is to get a low enough resonant freq to play well to below 1khz in a SMALLER dimensioned diaphragm . The free swinging ribbon does this easily as it is not clamped on all sides. The Dynaplane ribbon in these tests is only 14 mm wide and 3 inches long, and has a smooth roll off with no resonant bump all the way down to 300 hz. Makes crossover at 1K almost too easy.
Now here's something that will seem contradictory to what I have posted. When it comes to distortion I am in the camp that says its NOT as important as a smooth freq response and a good impulse/ CSD, and good dispersion out past at least 10K. We have been doing blind tests here on this forever. Its really easy to make two ribbons that are basically identical but one with the mod that produces an order of magnitude less distortion and the results show NO favoritism between the two. AND they sound the same and up to about 90 db measure the same.
Sooo why bother?? Two reasons
1- unfortunately the masses Believe that these low distortion numbers are important, and 2- because the mod that produces these low numbers also makes a ribbon that has the needed stability in the magnet gap and can structurally handle the lower freq cross over . It is a design that just happened to kill two birds with one stone. That alone is rare!!
BTW WrineX, as far as the high distortions at 100 dB on the Neo2. You are quite good at makin these things. Its serious easy to make a typical ribbon. I would throw a small one together and test at higher levels. You will see
Old 3rd November 2018, 03:06 PM   #6
BTW just a note on the title of the thred, "do you believe?"
I was working a bit with a guy, who will remain nameless, who is a writer in some audio publications. The plan was to have him test the original Dynaplane ribbon design , live with it for a while in different systems, write about it, and possably connect me with Parts Express for possible distribution.
However He kept advising me "not to lie". The remark was about my published distortion figures. Apparently He had past experience with a famous ribbon maker in past and he understood that free swing ribbons this size simply do not show these low numbers.
Long story short I have not perused the relationship. The guy at Impulse Audio seems like an straight shooter. I may see if He has interest in the future.
Old 3rd November 2018, 04:02 PM   #7
WrineX's Avatar
I never knew third could be above 2e. never ever ever seen that in any loudspeaker i made not even in ribbons, Rubanoides, Planars normal drivers,domes,EAPs,ESLS. so learn everyday probable will for the rest of my life
Yes a ribbon in theory is simple. although a perfect one is not i guess, i think Gerrit made a close one on that regard.
Yeah going in business straight of is scary and aparantly they had a bad experience
The dynaplane how does it look and work, or is that still in the trade secret (i would understand ) about the resonance, i am using this at the moment. not perfect yet in terms of i have to figure something about terminating the ends so it wont create resonances. but this small panel has a main res of 100 or something. (with huge distortion of course @ that freq)
this is still a non push pull system. will ad the backplate today see what happens only thing i am annoyed by is the dip at 12khz but the distortion looks on certain points between the clearly visible resonances even lower then the planar i posten an hour ago. (above)
i also tried horn loading it. no expert in horns at all but it does make te response reach lower even with the backside being open.
Old 3rd November 2018, 04:07 PM   #8
WrineX's Avatar
by the way i know see on the photo several things to lower resonances/distortion, for instance the turns are free to move. not cool since the direction of the field turns there. i used to thick laminate here/stiff/noisy aah well keeps me busy
Old 3rd November 2018, 05:52 PM   #9
Yes a large area planer will move so little that its distortion will be quite low, even non push pull.
As for 3rd harm above 2nd, I see this on every single FREE SWING ribbon I have ever tested at higher volume and I haven't yet seen published distortion at higher volume from other manufactures. I wonder why? . As far as I know Its fundamental issue of all tru ribbons I know of except the one I developed.
The original Dynaplane ribbon was a larger ribbon ( 20mm wide by 150mm long) that was good to 500 hz. I was awarded a patent on that one.
Heres the patent number if interested...
US 9668057 B1
You can see it at dynaplane ribbon loudspeakers
For various reasons I am discontinuing it but will continue to supply parts to those who need.
That one has a unique construction that gives more control over over excusion AND gives a higher spring rate along length without added mass allowing use to 500 hz BUT the reason for the low distortion in that design is hidden and at the time of the patent I missed it. The new version levers off from understandings learned from it and is a better ribbon, BUT I cant talk directly about the secret sauce Ha.
Old 3rd November 2018, 05:57 PM   #10
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by lowmass View Post
…notice that in the typical free swing ribbon as shown in the Neo 2 will have the 3rd harmonic ABOVE the 2nd harmonic at these higher volumes. With the Dynaplane ribbon that is switch around to what you typically see with planers and domes.
Very impressive! Thanks for sharing your progress.
Hopefully the patent application will be filed soon so you can talk a bit more freely about what is going on.
- Do you normally see 3rd harmonic stay so constant with frequency like shown in Post#1? The few ribbon I have measure generally had it falling off fairly quickly with increasing frequency. I guess that might also have to do with the transformer, if one is used.
- Can you comment on how distortion for your new and old construction techniques compare between monopole and dipole operation?
- Can you share any details on the waveguide profile used in the Post#1 measurements?
Just noticed your waveguide related thread in the Multi-Way Forum:
ribbons and wave guides
Last edited by bolserst; 3rd November 2018 at 06:25 PM. Reason: Add Link to Related Thread:
Do you believe?Hide this!Advertise here!
