Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Planars & Exotics ESL's, planars, and alternative technologies |
Thread Tools |
hi all
attached is a new type of speaker design walk around so can hang or go on a stand stereo and no moving coil no magnet and no cone ![]() can be further split for quadro etc and very high powered needs a tweak or two to the design but the basics is there the iron rings are bonded to the hemespherical wood sound emitter |
#2 |
Always good to see new concepts. The Rice-Kellogg cone driver is as close to over-bloated obsolescence as the internal combustion engine in cars.
Is it a Magnepan with mag-lev suspension?* Looks like there is a soft "surround" to support the diaphragm when the suspension power is off and to address front-to-back out of phase cancellation. Ben *I worked on mag-lev trains in the early 70's.
HiFi aspirations since 1957. "When the toilet paper of Experience is depleted, the backside of Reason goes unwiped" |
#3 |
By function a cone is a large area that moves air in a speaker. This one has a hemispheric radiator and so is an equivalent 'cone'. There are several coils. One shown behind the apex of the hemisphere appears to drive it and isn't that a 'moving coil' ? So the description appears to be misleading ?
A speaker that really fits most of the description would be a plasma speaker ( usually tweeter!).
AM |
#4 |
wow thats the first time i really have no clue how it works and what i am looking at
#5 |
hi
there is no moving coils the reflex dampen system isnt adjusted other than at power on the DC levitation can be modulated the hemespheres can be textured and the higher frequencies split off to drive the hemespere centers drive coil set the drive coils are mounted on disks the center of the hemesperes is a dual coil right and left there is no cone infact the exact opposite the drive system can be set up to accept line input and just one fet per coil on each ring the fixed point is enough to hold the hemespheres fully and the speaker will perform quite well but with active setup then it will sound much louder and clearer im sure as i say it will need tweaks and design thinking but i cant see anything like this anywhere anything similar and the SST split sphere tech has other uses forinstance it can be used as a very sensitive directional mic or as a transducer if made smaller or perhaps made of quartz self contained for cleaning pipes |
#6 |
Fun thing. Did you do a prototype yet?
#7 |
no just at the drawing stage and iron out problems before having to make another one
saves a bit of time ive done some spacial simulations seems to give a good projection of sound the texture of rings i think the problem i have is model software is rubbish at this kind of thing speaker design software all runs around cones and woden boxes if anyone has an idea of a good simulation tool as for the electronics this part is easy and very easy to build the iron ring can be replaced with iron slugs per coil step coupling core so this will reduce the weight and aid in resosnace.. i see this place and im thinking this is a good place to fire it at.. Last edited by simeon w; 23rd October 2016 at 07:29 PM. |
#8 |
simeon w, I still can't understand how it works (and I have impression that I am not the only one). Maybe some better picture will help?
#9 |
I don't understand how sound is produced without any moving part. Sound requires air as a medium , for the ear to hear. Something needs to move that. If there is vibration of the hemisphere then that is the moving medium, an equivalent cone ! In a plasma speaker even that does not exist but it works in a different way altogether.
If the coils do not move what do they do ? Generate a magnetic field which does what ? Can't figure out how this works ! ![]()
AM |
#10 |
me neither
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Magnet mounting dipole drivers w/high moving mass | matevana | Subwoofers | 12 | 10th July 2010 12:44 PM |
What currently available moving magnet cartridge is the best.??????.... | oldheathkitphil | Analogue Source | 28 | 12th April 2008 01:16 PM |
Moving Magnet Phono Load | 6f6 | Analogue Source | 6 | 16th February 2007 09:25 PM |
moving coil loading | lt cdr data | Analogue Source | 28 | 27th June 2005 09:50 PM |
any moving magnet drivers? | jcx | Multi-Way | 0 | 8th December 2004 02:23 AM |
New To Site? | Need Help? |
