Planars & Exotics ESL's, planars, and alternative technologies
Martin logan CLX mods
Old 28th October 2016, 05:34 PM   #61
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by ticknpop View Post
It means I was surprised - the new resistors and Wima cap in the HV setups sounded cleaner, more detailed - the first 15 minutes they seemed muddy and I thought I made a mistake or the new components were breaking down, then as the music played they got more resolving than the original parts. I didn't expect that.
It normally takes a quarter of an hour or more when you switch on the power to the bias for the charge on the film to settle; it is normally that they sound weak, muddled or both that first 15 or more minutes.
It's how the speaker works.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 28th October 2016, 10:26 PM   #62
DDzStereo is offline DDzStereo  Canada
I will get back to you on the switch position when I next work on the x-over. Hopefully 'ticknpop' brings the parts to TAVES this weekend.
Jan is most likely correct on the bias build up time, I can't confirm as I always wait at least an hour before doing any serious listening, my components need at least that amount of time to warm up.
Old 31st October 2016, 12:14 PM   #63
You could contact Support at MartinLogan | Premium HiFi Speakers for Home Theater & Stereo on the switch position
Old 31st October 2016, 02:24 PM   #64
TheMooN is offline TheMooN  United Kingdom
Thank you DDz, I did send an inquiry to ML Tech Support via the ML website a few days ago however I still await a response !
It all looks pretty straightforward, both switches to left factory flat setting, both switches to the right position for Level2 with one of the switches set to left one set to the right for level1 , unclear however which switch one should alter accordingly for Level 1 out of the two ? Or whether it doesn't matter which.
Old 3rd November 2016, 10:25 AM   #65
Hmmmmm, still awaiting any response from ML, a follow up inquiry emailed.
Old 4th November 2016, 11:49 AM   #66
Huzzzzah, response from Tech Support.
Switch closest to the rear of the box for 1dB , both switched for 2dB boost.
Old 26th November 2016, 10:56 PM   #67
Default CLX Switches for Bass Panel
I found a picture of the exposed switches, you can see the switch designations and activation arrows on the silkscreen
Old 4th June 2018, 03:35 PM   #68
Studley is offline Studley  United Kingdom
Has anyone tried modding the crossover on their CLX to enable bi-amping?
Old 16th September 2018, 04:05 AM   #69
ticknpop is offline ticknpop  Canada
The CLX crossover has a notch filter so not just a straight forward crossover to biamp with
Martin logan CLX modsHide this!Advertise here!
wtb martin logan cls,clx panels slr 5000 Swap Meet 4 4th November 2010 02:01 PM
Martin Logan CLX Borat Planars & Exotics 2 13th December 2009 04:29 AM
Martin Logan CLX distortion bolserst Planars & Exotics 6 12th August 2009 06:07 AM
Martin logan ascent jouch Planars & Exotics 0 25th March 2004 07:02 AM
X-Aleph and Martin-Logan Faber Pass Labs 2 7th November 2002 08:40 PM
