Planars & Exotics ESL's, planars, and alternative technologies
Anyone making Apogee bass panels ?
Old 15th February 2020, 09:13 PM   #201
DeltaStar is offline DeltaStar  Canada
DeltaStar's Avatar
David, There used to be Diva installation video on youtube, I think it was done in 4 parts, not sure if it is still there, BUT I believe I downloaded it and have it somewhere.
RedAlert, I have done as you said, the math didn't work, at least not for me, Apogee didn't corrugate the way were doing it, they used a narrow roller going across the ribbon, which I believe displace and stretch under pressure kept the ribbon at length, I seen a video of this as well many years ago from a factory tour, it still may be on audigon, unless it was removed. Al
Old 15th February 2020, 11:36 PM   #202
dacen is online now dacen  Norway
Take a look at page 2 in this file and you will see how Apogee did it. It is the exact same procedure.
File Type: pdf Scintillating Apogee Hifi News September 1985.pdf (395.5 KB, 50 views)
Old 16th February 2020, 02:01 AM   #203
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Thats the first time I seen their rollers and their close to an 1 1/4” in diameter thereabouts
That fine pitch makes sure all surfaces are contacted and pressed for consistency.
This work hardens the foil I believe just enough for long term durability
I wouldn’t be surprised if they also had alignment issues as they went and from the ( flat feed side only ! ) a slight pull keeps it straight and parallel as you go.
Hard to beat their roller system
David
Old 16th February 2020, 03:07 PM   #204
DeltaStar's Avatar
They must have made that corrugator later, it's not what I seen, also thier wrong on the scintilla circuit slits, 75 not 83
Old 17th February 2020, 04:10 AM   #205
Ordered the .557” Outer Diameter from DRP performance. The ones I got is too coarse. I do not want to use them.
Old 17th February 2020, 02:27 PM   #206
ABJensen is offline ABJensen  Denmark
Maybe with 4 off this
Ribbed / Smocking Rolling Pin 15 cm | Buy at Trade Price
Old 17th February 2020, 03:19 PM   #207
AVWERK's Avatar
At 9.5 in length and 2 bolted with an all-thread rod down the center of each plus a machined insert to capture each end, it would be hard to eliminate a joint line that would transfer to the foil.
Since there would be 2 joints to contend with and a double chance of this, one would have to live with the outcome. Another issue would be runout tolerances with 2 joints and 4 rollers
These rollers might work well for mid/twt ribbons though. Without a better close up of the ribs it appears the peaks are too rounded off and when placed together it looks like the foil might not reach the depth to make a clearly defined profile transfer.
Worth a shot though
Old 17th February 2020, 03:37 PM   #208
This is how it looks
Old 22nd February 2020, 10:50 AM   #209
trickydicky is offline trickydicky  United Kingdom
trickydicky's Avatar
Default I Have a Duetta foil rolled flat as best I can
I Have a Duetta Foil rolled flat as best I can prob another 10mm
Old 22nd February 2020, 12:39 PM   #210
RedAlert59 is offline RedAlert59  Finland
Very good, thanks . Could you please measure the distance between the first upper and bottom cuts of the flattened foil? When the distance between the first upper and bottom magnet rows is know, one should be able to estimate the effect of corrugation. How many cuts there are on Duetta-foil? When you know that, you could calculate the average distance between cuts and if the magnet rows are in the right places, cuts should be in the middle of every row.
Anyone making Apogee bass panels ?Hide this!Advertise here!
Making a bass cabinet, driver selection. ruerose Instruments and Amps 25 14th March 2015 12:36 AM
Making and onboard bass guitar preamp Skywalker83 Parts 8 17th October 2012 04:28 AM
4 GIK 244 Bass Panels (Boston no shipping) sts9fan Swap Meet 1 14th May 2008 06:33 PM
Making my 1st AMP! (40/60w Bass Amplifier) Shakal Solid State 19 12th June 2007 03:36 AM
Separate panels for bass? ak_47_boy Planars & Exotics 16 8th June 2007 11:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
