Planars & Exotics ESL's, planars, and alternative technologies
Anyone making Apogee bass panels ?
Old 17th November 2019, 09:12 PM   #151
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Originally Posted by AVWERK View Post
Post #91 I show widths of a Diva 1989 stock bass panel. I do not know the dims.
of other models and sure they vary across the range.
The rods you can get at DRP performance (off road) supplies. Anodized aluminum
They do sell an 1.125” diameter rod BUT it has same 9 peak profile as the 1/2” shown here and would be spread out even more and why I didn’t use the bigger version.
You will notice that the peaks and valleys do not follow a perfect 1 to 1 ratio as you would in say , straight cut gears in a racing transmission for instance, but anything in this length is difficult to find and while not what I would want ultimately, it is what it is..
A decorative light pole or floor mat pressed together�� might work hehe
David
Hmm i was hunting for crimp rods to extruded belt gear/pinion stock rod/bar woul;d work to, but i found the price still rather hefty.
when i think of it Coolblock in bar/rod should fit the bill to. often they are extruded , just like my crimper from the hobby shop. gone do some searching again, else i just machine some out of mdf or something im afraid and stack them
Old 17th November 2019, 09:16 PM   #152
WrineX's Avatar
extruded heatsink round - Google Search
what also could work, is buy serveral of those hobby paper crimp machines. (for me the best plan i gues) put them on a rodd , line them up and bolt them together they come often in 8inch long. so 4 of those lined up and some bearings should make a machine. in the worst cant you should have a idler wheel (riding the corugration wheel)in the middle keeping the rods from bending to much.
Old 17th November 2019, 11:10 PM   #153
AVWERK is offline AVWERK  United States
AVWERK's Avatar
From “L” bracket to L it is 30” long with a 20” cutout area
I did place some cutoff inner tube bands for a little more pressure on the rods
With a little spray lube to rotate easier
Less than 50$
I did think about a spring pressure upper rod with slidable greased plates on the outside L brackets
and might go this route since I would like to try the bigger diameter rods on another set
of wave cut foils
Old 18th November 2019, 08:44 AM   #154
WrineX's Avatar
Attachment 795716
From L bracket to L it is 30 long with a 20 cutout area
Less than 50$
of wave cut foils
Ha nice, i did not read you already addressed the bending ! great minds think alike .......i wish i could find that size of rod , although the corrugation is a rather funny one, they dont interleave like all that hard. it is far more gently to the foil i gues, did you corugate a test piece somewhere here ?
Old 18th November 2019, 02:36 PM   #155
AVWERK's Avatar
Post #118 is a comparison to a stock foil vs my version and 119 is the
complete panel
The peak of the corrugation does touch the valley depth but it doesn’t follow it perfectly
because the valley width is wider than the peaks profile
Not perfect , but close enough for a bass panel
Drp performance has all widths and OD diameters and made of 6061-T6 anodized aluminum
David
Old 19th November 2019, 11:16 PM   #156
AVWERK's Avatar
Another way to corrugate would be a ribbed floor mat.
One could take a plywood strip 4 wide by 20. 2 pcs and cut 2 sections of the mat and spray glue
To each side of each block the rubber mat and these would be used to compress across
each foil panel.
You just keep going line by line. It might be an issue on each start next to a finished line but worth a try on a test piece.
You might have to provide a depth stop on 1 board and the Kapton back soaped down as the width will draw the foil in due to corrugation shrinkage
You could get fairly accurate lines and not damage either side of the lamination.
I have not tried this, but seems doable and cheap
David
Old 20th November 2019, 04:05 PM   #157
Davey is offline Davey  United States
David.
'Real nice work on this! And definitely in the spirit of this forum.
Dave.
Old 20th November 2019, 06:11 PM   #158
lowmass is offline lowmass  United States
Ditto
Old 20th November 2019, 06:29 PM   #159
DeltaStar is offline DeltaStar  Canada
DeltaStar's Avatar
very nice work !!!
Old 20th November 2019, 07:03 PM   #160
AVWERK's Avatar
Thanx guys I appreciate it it !
Here is the start of the 2nd panel going thru the pasta machine
Anyone making Apogee bass panels ?Hide this!Advertise here!
Making a bass cabinet, driver selection. ruerose Instruments and Amps 25 14th March 2015 01:36 AM
Making and onboard bass guitar preamp Skywalker83 Parts 8 17th October 2012 05:28 AM
4 GIK 244 Bass Panels (Boston no shipping) sts9fan Swap Meet 1 14th May 2008 07:33 PM
Making my 1st AMP! (40/60w Bass Amplifier) Shakal Solid State 19 12th June 2007 04:36 AM
Separate panels for bass? ak_47_boy Planars & Exotics 16 8th June 2007 12:44 PM
Copyright ©1999-2019 diyAudio
