PC Based Computer music servers, crossovers, and equalization
Win XP system, Foobar2000 and Boom problem
Thread Tools
Old 30th November 2020, 05:07 AM   #1
N101N is offline N101N
Default Win XP system, Foobar2000 and Boom problem
In my Win XP system Foobar2000 and Boom do not work while all other similar applications do. Getting the error message for MP3: "Decoding failure at 0:00.000 (Unsupported format or corrupted file) Unrecoverable playback error: The parameter is incorrect. (0x80070057)"
Wrong codec?
Old 30th November 2020, 06:51 AM   #2
AllenB is offline AllenB  Australia
AllenB's Avatar
Thread moved
Old 30th November 2020, 07:11 AM   #3
Thank you very much, Allen.
Old 10th December 2020, 01:51 AM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I wrote some DJ music player software for my PC.
Worked well for many years.
Then one day it started to fail.
Spent hours debugging software and couldnt find the problem.
I then noticed PC started going wrong with other programs.
I reinstalled Windows and it was no better.
I did hard drive and DRAM checks using debug software.
They said they were fine.
In desperation I removed one of my DRAM modules but still no better.
I replaced it and removed the other and suddenly everything was good again.
I wasn't convinced there was anything wrong with the DRAM module as I hadn't had it long.
So got the motherboard manual out.
Apparently if you fit two DRAM modules they must be in same colour slots.
So I put the "faulty" DRAM module back in to the right coloured slot and its been fine since.
Not saying that's your problem but problems can in one of many sources.
2021 versions of PCBCAD51 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
Old 10th December 2020, 03:18 AM   #5
Thank you for responding. I use 100% reliable Micron memory modules.
Not a big issue, I was just a little bit curious about that unnecessary dependency. It can be a missing registry key. In my system, most unused items have been removed.
Old 12th December 2020, 03:07 AM   #6
Probably my last question: why is Foobar2000 so popular?
Old 12th December 2020, 04:21 AM   #7
DRONE7 is offline DRONE7  New Zealand
@N101N
to quote Byron...
"Mediocrity is achievable... this may explain its popularity"
There, may be my last answer too...
shields up, takes cover... slopes off to a Linux box... lol folks... don't take life too seriously..
Old 12th December 2020, 04:51 AM   #8
I have not expected such a philosophical explanation. I agree that popularity is a poor measure of quality.
Old 12th December 2020, 05:11 AM   #9
asuslover is offline asuslover  Romania
Spend 5$ for win10 key from eBay , let the xp rest.
Old 12th December 2020, 05:28 AM   #10
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Yeah, I've been using Foobar2000 for many years, and that's running Win7-64. Can't believe someone's still using XP.
jeff
Win XP system, Foobar2000 and Boom problemHide this!Advertise here!
Thread Tools
Leap/LMS system with Win 98 computer woofertester Swap Meet 1 10th March 2018 03:16 AM
foobar2000 and vinyl playback arg_ Digital Source 1 17th August 2014 07:04 PM
Foobar2000 and other things digital Bob Brines Digital Source 25 12th March 2012 04:52 AM
Digital Room Correction and Foobar2000 Convolve mr.duck Digital Line Level 1 23rd June 2009 05:49 PM
Netjack2 - Foobar2000 (or any other win32 player) and jackrouter asio driver Theo404 Digital Line Level 5 19th April 2009 05:08 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
