How do I have a 1st order filter with Equalizer APO? In the list of filters there is no option for 1st order filter.
Also how do I add boost/gain to a single channel?
I am using Peace to configure EqualizerAPO
Thanks,
WA
Thanks,
WA
Strangely, first order filters are missing in EqualizerAPO.
You can define one yourself with the free filter, but then you need to calculate the filter coefficients yourself.
Filter with custom coefficients (since version 0.9)
Syntax:
Filter <n>: ON IIR Order <m> Coefficients <b0> <b1> ... <bm> <a0> <a1> ... <am>
Description:
Adds a generic IIR filter with the given order and coefficients. The number of coefficients must be 2*(order+1).
For channel operations you just use Channel: command to target.
etc.
1st order filtering goes as like Henrik wrote. An example:
Channel: L
<your operations for L channel>
Channel: L R
<your operations for L & R channels>
etc.
Code:
# Massberg Analog-Matched 1st order LP filter
# Based on: [url=https://tinyurl.com/ya8no96r]Designing Audio Effect Plug-Ins in C++: With Digital Audio Signal Processing ... - Will C. Pirkle - Google Books[/url]
# Brought to you by [email]jiiteepee@yahoo.se[/email] (8/2018)
Eval: fs = sampleRate
# User parameter ---------------------------------------
Eval: fc = 1000
# calculations
Eval: g1 = 2 / sqrt(4 + (fs/fc)^2)
Eval: gm = max(sqrt(0.5), sqrt(g1))
Eval: wm = (2 * pi * fc * sqrt(1 - gm^2))/gm
Eval: Om = tan(wm / (2 * fs))
Eval: Os = Om * sqrt((gm^2 - g1^2) * (1 - gm^2)) / (1-gm^2)
Eval: g0 = Os + 1
Eval: a0 = (Os + g1)/g0
Eval: a1 = (Os - g1)/g0
Eval: b1 = (Os - 1)/g0
# filtering
Filter: ON IIR Order 1 Coefficients `a0` `a1` 1 `b1`
You can use that latter code I gave for HP1 because of you probably can't turn that Massberg LP1 into HP1 without thinking a fully new design.
So, for HP1 in EqualizerAPO, you write:
Code:
# cut off frequency
Eval: fc = 1000
Eval: w0 = 2.0 * pi * fc/sampleRate
Eval: a0 = cos(w0) + sin(w0) + 1
Eval: a1 = sin(w0) - cos(w0) - 1
Eval: b0 = cos(w0) + 1
Eval: b1 = -(cos(w0) + 1)
# filtering
Filter: ON IIR Order 1 Coefficients `a0` `a1` `b0` `b1`
Hello,
just tried it:
its doing something, but it does sound like an high pass.
Where did this whole part go?
just tried it:
- PC Based
- First order filter with Equalizer APO/Peace
