PC Based Computer music servers, crossovers, and equalization
FIR-LADSPA: A LADSPA plugin for FIR filtering
Old 30th March 2020, 08:08 PM   #41
CharlieLaub is offline CharlieLaub  United States
Originally Posted by HenrikEnquist View Post
Typo! You have "single" for both float and double.
Right, just fixed that, too. Thanks for pointing it out.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 30th March 2020, 09:51 PM   #42
Originally Posted by flangaman View Post
flavio-PC LADSPA-FIR # chmod +x ./compile_FIR_engine.sh
flavio-PC LADSPA-FIR # ./compile_FIR_engine.sh float
compiling the FIR engine in single precision...
The FIR engine was successfully compiled into the executable file FIR_engine.exe
Perfect.
And to think that I do everything with copy and paste in order not to be wrong!
I am happy to have had two saviors on your level.
Now that I have compiled my Ferrari, I greet you and thank you.
See you when I learn to drive.
Ciao.
Grazie mille!
Drive carefully.
Old 31st March 2020, 05:10 PM   #43
Just in case people don't know... you can use ecasound+LADSPA in combination with Pulse Audio. This You can implement both IIR and FIR filters via that route.
ALSA has a Pulse device, which IIRC appears as a virtual "monitor" device in Pulse and gets all the sounds the system sends to Pulse Audio. So, in Pulse you disable the output device you wish to use. Then you tell ecasound to use the ALSA pulse device as the input, and send the output to the soundcard you deactivated under Pulse. You can still use the Pulse audio volume control, which is very convenient, and everything works just the same as if playback was coming via Pulse except you get crossover functionality via ecasound. I use this approach on one of the systems in my home.
If someone would like, I can provide a more detailed example.
FIR-LADSPA: A LADSPA plugin for FIR filteringHide this!Advertise here!
LADSPA plugin programming for Linux audio crossovers CharlieLaub PC Based 482 5th February 2020 09:33 PM
LADSPA plugins arjunm009 Digital Line Level 2 24th October 2018 01:52 PM
asoundrc and ladspa RAndyB PC Based 8 18th March 2018 01:03 PM
IDEA: Linkwitz-Transform LADSPA plugin with lookahead boost control CharlieLaub PC Based 63 29th April 2016 04:05 PM
LADSPA help, please! Deafuser PC Based 10 17th February 2016 08:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
