PC Based Computer music servers, crossovers, and equalization
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
Old 19th September 2020, 01:14 AM   #841
seashell is offline seashell
I imagine websocket is also more portable between windows and linux than standard sockets anyway.
Switching to json sounds like a good idea. There are json parsers for pretty much everything and it's easy to decipher as plaintext too.
My mention of console to websocket was only in the context of maybe it would be the easy. Since you've stated that's not the case I don't see it as being very important. It sounds like you're already planning to add the useful information to the websocket.
Old 20th September 2020, 08:00 AM   #842
tweakgames is offline tweakgames
Hello.
I am really enjoying CamillaDSP. Thank you.
I attempted to look through the 85 pages, quickly, and search, but I didn't find any obvious response to this.
Before I drive myself crazy, is this known or expected:
Windows 10.
Using VB-Cable
I am able to set the (Playback) CABLE Input to 5.1 by doing "configure speakers", but I am unable to get the (Recording) CABLE Output to do more than 2 channels.
From what I can tell, that means, when I try:
capture:
type: Wasapi
channels: 6
device: "CABLE Output (VB-Audio Virtual Cable)"
format: FLOAT32LE
I end up with:
Capture error: The requested stream configuration is not supported by the device.
However, I can set the capture back to 2 channel, configure my onboard sound card to 5.1, and set it to 6 speakers:
playback:
type: Wasapi
channels: 6
device: "Speakers (Realtek High Definition Audio)"
format: FLOAT32LE
and use mixers to output any of the 2 captured channels from the Cable Output to any of the 6 channels on the Realtek correctly.
Does this make sense? Is this a known limitation of VB-Cable and/or windows 10? Some research has shown that Windows XP allowed 8 channels of recording.
Thanks!
Old 20th September 2020, 08:07 AM   #843
phofman is online now phofman  Czech Republic
IME the VB cable has many limitations. I tested the free version for bit-perfection when trying to run my distortion-compensation tool on windows and have never attained 24bit perfection of the loopback. I would not be surprised if it supported two channels only.
Jackd + JackRouter ASIO driver are bit-perfect (and probably support any channel count you want). Just operation of the chain is more complicated because you have to start components in correct order for the whole chain to run correctly with no error messages.
Old 20th September 2020, 08:17 AM   #844
phofman, thank you very much! I will look into that shortly! Looks like the Windows installers may be difficult to find.
Old 20th September 2020, 08:52 AM   #845
Good luck. Windows is a P..A to do any non-standard audio setup, the OS itself lacks most of the important building blocks, "standards" change with every version, very little open source is available due to the driver/app signing craze. Only third-party proprietary tools are available, often buggy with blurr chances of improvement.
I believe a much more reliable way is building the whole chain in embedded linux running on inexpensive HW and presenting the device to windows as standard USB-audio gadget, just to use the dummy windows for GUI playback and control. The linux USB gadget supports combined mode where usb-audio and USB-network devices can run concurrently, allowing control of the linux chain via windows browser. That is a plan for my next project and CamillaDSP already has a great web interface.
As a step forward, linux has a reliable USBIP toolset and even supports hooking the USB gadgets to the USBIP driver, allowing to connect the virtual USB devices over regular network - 100m range, galvanic isolation for free. I tested USBIP some time ago, worked great Linux host - linux device while getting some bug windows host - linux devices. But the USBIP developers are working hard to iron the problems out Issues * cezanne/usbip-win * GitHub
Old 20th September 2020, 09:02 AM   #846
Releases * jackaudio/jack2-releases * GitHub
For installation I think I followed steps in Using JACK on Windows | JACK Audio Connection Kit
Old 20th September 2020, 07:24 PM   #847
HenrikEnquist is offline HenrikEnquist  Sweden
Hello.
Windows 10.
Using VB-Cable
capture:
type: Wasapi
channels: 6
format: FLOAT32LE
I end up with:
playback:
type: Wasapi
channels: 6
format: FLOAT32LE
Thanks!
I have only tried stereo before, but I tried to record more channels now. I also can't get VB-Cable to output more than two. Seems to be a known limitation since Windows Vista: 5.1 with Virtual Cable? - VB-Audio's Forums
Old 20th September 2020, 07:32 PM   #848
The ASIO part may be a showstopper here(?).
There is ASIO support in CPAL and I have tried enabling it for CamillaDSP. It does kind of work, but with many problems. First of all it's limited to 16-bit for most hardware. And there were strange problems when closing devices which caused problems both when exiting CamillaDSP and when reloading the config. I decided to not include this in CamillaDSP yet and I haven't had time to look into it any further
Old 20th September 2020, 07:38 PM   #849
Is it possible to use the audio gadget mode with windows now? I tried it with my pi4 (raspbian 10.3, kernel 4.19.97), and windows found the device but could not start it. I googled a bit and it seems the gadget is missing some stuff that windows requires. It it working with more recent kernels?
Old 22nd September 2020, 07:22 PM   #850
xorcz is offline xorcz  Czech Republic
In the GUI I cannot change to PulseAudio:
020-09-22T19:20:17Z ERROR camillalib::socketserver] Config error: devices.capture.type: unknown variant `PulseAudio`, expected one of `Alsa`, `Pulse`, `File`, `Stdin` at line 7 column 11
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.Hide this!Advertise here!
The room correction or speaker correction? What can we do with dsp power now availabl Raimonds Full Range 233 28th January 2017 07:51 AM
Introducing OpenDRC, Open Digital Room Correction engine minidsp miniDSP 20 20th January 2016 05:37 PM
What the difference between dsp room correction eq and software correction erez1012 PC Based 0 10th March 2014 07:07 PM
Writing a Cross-Platform, Free Software Modeling Tool and TS-Parameter DB justinzane Software Tools 6 31st December 2013 06:55 AM
FS: DAC, room-correction, active crossovers, amp, speakers! taloyd Swap Meet 4 14th April 2009 03:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
