PC Based Computer music servers, crossovers, and equalization
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
Thread Tools
Old 30th May 2021, 07:06 PM   #2051
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Kool
Mark
www.kravchenko-audio.com
Old 30th May 2021, 08:51 PM   #2052
taotao is offline taotao  Germany
Default Definition of Q in a shelving filter fails
H Hendrik,
according title of this post; see attachement.
I'm running:
CamillaDSP 0.5.2
pyCamillaDSP 0.5.0
Backend 0.7.1
Thank you.
Best regards
Olaf
Old 30th May 2021, 09:07 PM   #2053
TNT is offline TNT  Sweden
- Peaking, Notch, Bandpass and Allpass filters can be defined with bandwidth.
Very nice!!! Will make things easier. How is BW defined?
- Highshelf and Lowshelf can be defined with Q-value.
Wasn't this already available...?
More distortion to the people! Timing . . . . is paramount.
Old 30th May 2021, 09:12 PM   #2054
HenrikEnquist is offline HenrikEnquist  Sweden
Originally Posted by taotao View Post
H Hendrik,
I'm running:
CamillaDSP 0.5.2
pyCamillaDSP 0.5.0
Backend 0.7.1
Did you perhaps miss to update pycamilladsp-plot?
CamillaDSP - cross platform dsp engine
Reporting an issue with CamillaDSP? Please attach the config file and the log from a run with "debug" log level.
Old 30th May 2021, 09:19 PM   #2055
Same way as "everyone else" does it: bandwidth in octaves. For bandpass and notch it's the width between the -3 dB frequencies. For peaking it's between the midpoint (gain(in dB)/2) frequencies.
Nope! Those had only slope, in dB/octave.
Old 30th May 2021, 09:42 PM   #2056
How about an early preview of the new Wasapi backend?
Release v0.6.0 beta1 * HEnquist/camilladsp * GitHub
The Wasapi capture and playback devices now have a new optional parameter "exclusive" to enable exclusive mode. In that mode, the Windows mixer etc are bypassed. The sample format must be one that the device driver supports directly. Try S16LE or S24LE3 first.
This is using a new Wasapi binding I built using the Rust for Windows crate: https://crates.io/crates/windows
I haven't worked with any Windows api before, and I must say it has been a quite positive experience. The Wasapi api is nice and easy to use and the documentation is quite good.
Old 30th May 2021, 10:05 PM   #2057
Thanks, working now.
I updated pycamilladsp-plot to 0.5.3 under user Root, should have been user pi.
Old 30th May 2021, 10:10 PM   #2058
Q-Factor and Bandwith calculator can be found here :
Q factor vs bandwidth in octaves band filter -3 dB pass calculator calculation formula quality factor Q to bandwidth BW width octave convert filter BW octave vibration mastering slope dB/oct steepness EQ filter equalizer cutoff freqiency - sengpielau
Olaf
Old 30th May 2021, 10:37 PM   #2059
Default Housecurve
Henrik,
Is it possibble, to build a shelving filter in camilladsp according attached REW screenshot (the falling part starting at 1kHz)?
The plot looks rather strange (I didn't measure yet); the slope starts quite early, but not at 1 kHz.
Old 31st May 2021, 06:33 AM   #2060
The frequency setting of a shelving filter means the middle of the slope, not where it starts or stops. To make something similar to that curve, try for example frequency = 4000, slope = 1.0, gain = -4.0. You will have to play around a bit until you find a good match. Also note that at such low slopes, the sloping part gets a bit wiggly.
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.Hide this!Advertise here!
Thread Tools
The room correction or speaker correction? What can we do with dsp power now availabl Raimonds Full Range 233 28th January 2017 07:51 AM
Introducing OpenDRC, Open Digital Room Correction engine minidsp miniDSP 20 20th January 2016 05:37 PM
What the difference between dsp room correction eq and software correction erez1012 PC Based 0 10th March 2014 07:07 PM
Writing a Cross-Platform, Free Software Modeling Tool and TS-Parameter DB justinzane Software Tools 6 31st December 2013 06:55 AM
FS: DAC, room-correction, active crossovers, amp, speakers! taloyd Swap Meet 4 14th April 2009 03:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
