Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
PC Based Computer music servers, crossovers, and equalization |
Thread Tools |
#1691 | |
The only problem I can think of is if your script takes a very long time to run. Then Alsa could complain that it's taking too long to open the device.
CamillaDSP - cross platform dsp engine Reporting an issue with CamillaDSP? Please attach the config file and the log from a run with "debug" log level. |
#1692 |
I am trying to get ALSA and PulseAudio to both use the alsa_cdsp automatic rate switcher interface to CamillaDSP.
Could someone recommend a functional configuration to get the PulseAudio Loopback to work with the alsa_cdsp ALSA/asound.conf implementation ? I have tried various versions, but am not able to get the default audio to launch it via the Loopback. Alsa_cdsp works fine if the app writes to "camilladsp" and PulseAudio Loopback works with the non-alsa_cdsp implementation. Unfortunately, not all apps allow "camilladsp" to be specified. If the app writes to the -D "bridge" "type asym" version the alsa_cdsp playback works (same for the "type copy"), but if the app writes to the -D Loopback or default device, the capture from the Loopback does not work. The Loopback is Card 0 devices 0 and 1 in the list and startup daemon is not running (as per the alsa_cdsp docs) to keep it from conflicting. Any suggestions would be much appreciated. Code:
# Copy to /etc/asound.conf pcm.!default { type plug slave.pcm "bridge" } #pcm.bridge { # type copy # slave.pcm "camilladsp" #} pcm.bridge { # Attempt to read from Loopback and write to camilladsp type asym capture { pcm "hw:Loopback,1" } playback { pcm "camilladsp" } } pcm.camilladsp { # SeaShell's alsa_cdsp automatic output rate switcher type cdsp cpath "/pathto/camilladsp" config_out "/pathto/config_out.yml" config_in "/pathto/config_in.yml" channels 2 rates = [ 44100 48000 88200 96000 176400 192000 352800 384000 ] cargs [ -p "1234" -a "0.0.0.0" -l warn ] extra_samples 0 extra_samples_44100 8192 extra_samples_48000 8916 } ctl.!default { type hw card "Loopback" } ctl.bridge { type hw card "Loopback" } |
#1693 | |
Now for the OS:- Simply because the 32bit x86 listed as a fully approved download from raspberry pi org, is available as an img file to be written direct to a microSD card. (Ie. boots from a USB Micro SD reader, as a self contained system,- with "persistence" not off a hard disk). Why would they do that? ![]() Because they are stupid? I don't think so, some good reasons:- Because it enables rapid familiarity with the entire RaspiOS world at high speed on "buster",- That made it a lot easier to get many programs working on the ARM64 raspi system without the uphill struggle of re-evaluating everything. You do your homework on a x86 USB card, then pull it out and plug it into the USB slot on the 64 bit Pi. Some of us don't happen to believe in Intel/X64 anything an more, least of all because my Raspi uses 5W of power, whereas the average notebook uses 60-80W. There are very many advantages with microSD & swappable media in general which make hard disk systems/USB sound cards look pretty weak. They can be cloned in minutes, cost peanuts, are easily transferrable between one computer and another, and can transfer the work from ONE OS to another. Also it so happens a notebook equipped with a studio quality PCMCIA card has direct hi speed bus access to PCI, which nothing else does. (PCMCIA was an excellent standard which the tech boys threw under a bus 'scuse the pun!) This brings down latency. It means you can swop the card into another machine in seconds. (Yes now who in their right mind would use a win 32 server OS on a notebook? me,- because it's much more stable) I get kinda ratty about people who start criticising & questioning decisions for the sake of it.. That is what appears to be the general drift of all the criticisms of what I am doing and why. |
#1694 |
OK, we fixed it.
Rew displays the DSP corrections exactly as it should. The return measurements are edited elsewhere, and a quick run was done. The whole running "REW on linux" Java8 problems esp with the latest distro "Buster", all turns out to be a waste of time. Running Camilladsp on ARM64-Linux* works reliably 24/7 without any glitches. I don't need AMD64 at all. Arm64 + camilla all start auto as a services, as does VLC, plus the whole test sequence can now be fired up via the web interface of VLC, and uses about 4-5W of power. Which means it can be left for a day on a car battery without making it impossible to start the engine 24hrs later. (this makes it possible to run the whole box & make measurements in a car - a sine qua non of the whole op.) Measurements run fine on win32, and the results now display fine in REW. QED. ![]() Here are the headphone correction graphs which started all this off. The corrections on the yml file are visible enough to be able to know what to do with the "Q" factor and resonance Frequency nulling to be able to refine the graphs properly. ![]() NB:- *Arm64 Linux (debian) on Raspberry pi, was considered quite "bleeding edge" until last autumn. |
#1695 | |
I have tried to use the alsa_cdsp plugin from Pulse just once to check that it works. It was a while ago so I'm not sure I remember it right, but I think I had an Alsa config for the plugin just like in your asound.conf. And then I think added an alsa-sink to PulseAudio with like this: Code:
pacmd load-module module-alsa-sink device="camilladsp" sink_name="CamillaDSP" pacmd update-sink-proplist CamillaDSP device.description=CamillaDSP You don't need any loopbacks. You can add those commands to your pulseaudio config file (without "pacmd" then).
#1696 |
Final note on REW on linux, then let's drop this topic.
Here is a picture of REW running on Raspberry Pi Desktop (i386) in a virtual machine on my laptop: Screenshot from 2021-03-04 08-59-59.png I got JRE8 from the link xorcz posted, followed the 2-line instruction for installing it, and then downloaded and installed REW. Done.
#1697 | |
![]() Quote:
Code:
rates = [ 44100 48000 88200 96000 176400 192000 352800 384000 ] Forex /pathto/config_out_$samplerate$.yml (allow the user to use the $samplerate$ token in destination path and filename). Code:
/pathto/config_out_44100.yml /pathto/config_out_48000.yml /pathto/config_out_88200.yml /pathto/config_out_96000.yml /pathto/config_out_176400.yml /pathto/config_out_192000.yml /pathto/config_out_352800.yml /pathto/config_out_384000.yml Last edited by emailtim; Today at 07:11 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
The room correction or speaker correction? What can we do with dsp power now availabl | Raimonds | Full Range | 233 | 28th January 2017 08:51 AM |
Introducing OpenDRC, Open Digital Room Correction engine | minidsp | miniDSP | 20 | 20th January 2016 06:37 PM |
What the difference between dsp room correction eq and software correction | erez1012 | PC Based | 0 | 10th March 2014 08:07 PM |
Writing a Cross-Platform, Free Software Modeling Tool and TS-Parameter DB | justinzane | Software Tools | 6 | 31st December 2013 07:55 AM |
FS: DAC, room-correction, active crossovers, amp, speakers! | taloyd | Swap Meet | 4 | 14th April 2009 04:16 PM |
New To Site? | Need Help? |
