PC Based Computer music servers, crossovers, and equalization
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
Thread Tools
Old 10th October 2020, 11:35 PM   #1021
wineds is online now wineds  Australia
In case you want to try to build squeezelite_custom to solve your JL problem @audiac proposed some alternatives here :
Also there is a thread on building squeezelite here :
Build Squeezelite
@audiac 's first approach is a variation on Jespers which avoids hard coded paths to all the .py files.
I might give this a shot today if I can find the time.
Old 11th October 2020, 12:41 AM   #1022
seashell is offline seashell
Or you could try the alsa pcm hook with standard squeezelite.
Old 11th October 2020, 03:36 AM   #1023
Yeah that is probably the way go thanks. I tried to apply Jespers mods to what I think is the latest squeezelite build 1278 but CamillaDSP throws error 'EINVAL: Invalid argument' when you try to change sample rate.
I had a look at your github. I'll study it some more and have a crack at implementing it. Thanks!
Old 11th October 2020, 07:15 AM   #1024
audiac is offline audiac  Sweden
As a matter of fact, I did not manage to get either Lykkedk's or my two modified squeezelite variants to work. The code I put together is therefore not guaranteed to work. Please report your progress.
I also believe that seashell's approach is very interesting. But, after a few hours trying, I couldn't make that work either.
Seashell, please explain more about how it is supposed to be configured. As for now, opencmd and closecmd will never fire. I'm just trying to touch files in /tmp, but nothing.
The asound.conf that you have on github, should the content be added to any existing asound.conf, or does it work for you as it is?
Old 11th October 2020, 10:25 AM   #1025
Maybe getting too off topic here but I successfully built and applied Jespers mods with this version :
GitHub - ralph-irving/squeezelite at 57108946f2117ea0552eab271b81c48fd14387e7
Probably that was the current build at the time.
Old 11th October 2020, 12:17 PM   #1026
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Nice...
I will when i'am getting smarter, do what Henrik suggested some time ago, making a repos. for the squeezelite build... I'am not there yet, sry...
Jesper.
DCG3 Dual DCSTB, AK4490 Dual SuperDAC
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html. Github https://github.com/Lykkedk/SuperPlayer
Old 11th October 2020, 12:25 PM   #1027
lykkedk's Avatar
Default SuperPlayer upgrade
Hello all
I did a new "howto" GitHub - Lykkedk/SuperPlayer_v2.0
This upgrade guide, uses the p.t. newest builds of the CamillaDSP, Camilla Gui etc... Plotting is not yet enabled as the mathplotlib is very heavy.
I donno if i will make this option work, but the rest is running fine, giving the player a few more seconds for starting up everything is running fine.
I attached a "top" picture of it running on a RPI 3, so i guess running it on a RPI 4 it will be much better?
Jesper.
Old 11th October 2020, 01:56 PM   #1028
TNT is offline TNT  Sweden
GUI config status - old status remains... even if new file is loaded I still see this old message..
More distortion to the people! Timing . . . . is paramount.
Old 11th October 2020, 02:10 PM   #1029
Playing a 44,1 ksps track (CD rip) I experience slip (ticks, pops, micro short stutters) while playing say every 10-30 seconds. I use VLC as player but also on other sources.
Also, the first 100 ms of each tracks seem to not play out.
Old 11th October 2020, 02:15 PM   #1030
pi r is offline pi r  Sweden
I'm pretty embarrassed to smear Henrik's CamillaDSP-tread with these of-topic posts.
But Jesper (lykkedk) has yet not started his own tread on his GitHub-project. - So where else should we go..?
I went to cPC to find out what squeezelitle they use.
Squeezelite | piCorePlayer documentation
And they use this set of build options:
Code:
Build options: LINUX ALSA EVENTFD RESAMPLE FFMPEG OPUS VISEXPORT IR GPIO RPI DSD SSL NO_SSLSYM
My guess is that the missing piece in Jesper's build of squeezelite-custom is the option: VISEXPORT.
I have yet not taken the measures to create a build environment for a Rpi.
So I kindly ask Jesper... could you..? (or someone else)
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.Hide this!Advertise here!
Thread Tools
The room correction or speaker correction? What can we do with dsp power now availabl Raimonds Full Range 233 28th January 2017 07:51 AM
Introducing OpenDRC, Open Digital Room Correction engine minidsp miniDSP 20 20th January 2016 05:37 PM
What the difference between dsp room correction eq and software correction erez1012 PC Based 0 10th March 2014 07:07 PM
Writing a Cross-Platform, Free Software Modeling Tool and TS-Parameter DB justinzane Software Tools 6 31st December 2013 06:55 AM
FS: DAC, room-correction, active crossovers, amp, speakers! taloyd Swap Meet 4 14th April 2009 03:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
