PC Based Computer music servers, crossovers, and equalization
APPLE vs Windows for music server.
Old 15th October 2019, 08:50 AM   #11
Tromperie is offline Tromperie  Australia
Or you could go to the local tip (rubbish dump) and pick up an old PC, as I did.
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 15th October 2019, 10:26 AM   #12
DRONE7 is offline DRONE7  New Zealand
Then, once you have tried the rest (of the X86 versions ;-) ..)
Then try the best.....but be prepared to work a bit harder for it...
wtfplay-project.org
wtfplay project - Linux based PC playback system
Old 15th October 2019, 12:46 PM   #13
phofman is offline phofman  Czech Republic
How do you measure "the best"? Any measurements/blind tests to confirm the digital or analog output is different than from a regular linux distribution?
Old 15th October 2019, 09:27 PM   #14
wtfplay-project.org
Unless it has the usability and ease of control of Daphile, it is not 'better', given both are digital.
Old 15th October 2019, 09:44 PM   #15
Oneminde is offline Oneminde  Sweden
For some its very important to be able to fiddle with code and do things in the background. I had a friend who was like that, he needed that level of control. I do not So better isn't always a reflection of quality. Daphile check's many boxes, but I want to read up on it and follow the development since launch and get an idea of what people typically do - in terms of hardware, cost levels etc. Just because it is DIY and freeware does not mean it has to be put together with dirt cheap stuff. The hardware aspect is just as important as the software, but that's just my opinion
In order to become sane in an insane world, you must first become insane.
Old 15th October 2019, 09:53 PM   #16
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
iTunes and Apple Lossless are not only good, they make it easy for us old boys.
Old 15th October 2019, 09:59 PM   #17
JRiver is much better, in fact i HATE Itunes UI and it does not matter if the software core is excellent ... even apple is moving away from Itunes. If I did a Hakintosh I would use JRiver.
Old 15th October 2019, 10:15 PM   #18
JamieMcC is offline JamieMcC  United Kingdom
Been using iTunes for years its easy to do and integrate with other devices. Recently I moved to Roon and migrated my iTunes library to a ssd attached to my Roon Rock server.
Very impressed by the step up in sound quality. If Roon can integrate Amazon hd into their platform as well I will probably go for a lifetime subscription
Old 15th October 2019, 10:20 PM   #19
Amazon is interesting
Amazon takes on Tidal, Deezer, and Qobuz with Amazon Music HD: a high-res music service | TechHive
Old 15th October 2019, 10:43 PM   #20
MAAC0 is offline MAAC0  Portugal
I believe years ago the Motorola based Apple hardware had better specs and had fewer crashes. Photographers still prefer IOS, but today IOS runs also on Intel platforms, so it should be the same.
If you look at Apple hardware perhaps You can still find better specs.
Steve Jobs was a visioneer and made some awesome beautiful and pricey products and was ahead of it's time, but never convinced me, but I own an IPOD video.
APPLE vs Windows for music server.Hide this!Advertise here!
Music Server with Improved Apple Airport Express cdfr Digital Line Level 123 27th September 2018 03:52 PM
Apple Music Mike Gergen Everything Else 1 9th May 2016 05:41 PM
FS : Windows server 2012 R2 essentials benja400 Swap Meet 0 10th April 2015 03:35 PM
How to Guide: Turn Windows XP PC into a Music Server miragem3i PC Based 34 18th December 2014 01:56 AM
Windows 8 Music Server on the Cheap ttan98 PC Based 5 21st November 2014 05:54 PM
Copyright ©1999-2019 diyAudio
