Bonjour à tous, j'utilise actuellement volumio avec rasp PI3b+ et liaison I2s vers ak4399.
Est-ce que hifiberry os pourrait fonctionner dans cette configuration?
Je vous remercie.
Hi Dugain,
HBOS auto detect your sound card. So maybe on first boot it could not work !?
But you can try! edit "/boot/config.txt" and add "dtoverlay=hifiberry-dacplus"
And cross fingers...
Is it possible to have this Trackball with Scrollring plug in to the PC via USB and with magic it ist a volumepoti and play and stop dan skip
without any configuration comandline hassle
Orbit(R) Trackball mit Scroll Ring | Trackballs | Kensington
Is it possible to use this os without hifiberry HW? I installed it on a naked pi, i can connect sources to it but i get no sound using the onboard sound-output. I know, the onboard quality is bad - i just want to test it
Hi Putzeudel,
I do not think so. Dugain is trying to use it with GPIO and external DAC but it seems quite difficult to make it work.
Hi Putzeudel,
I used it successfully with an IQaudIO Digi+, which the OS thought was an HFB Digi.
Hi Yatsushiro,
HB drivers are used for many HAT but there, Putzeudel and Dugain have no HAT!
The sound card they use can have differents audio chips than HB ones.
So it can make bugs...
I read on this forum (don't remind where exactly) that HBOS resamples to 48kHz.
You can have a look to diagnostics window to check this:
New release 20200629
(built-in update tool)
new feature to handle local music storage.
Not tested yet.
Hi Nico thank you for the news I have just check 20200701 version and it works with an usb key hot plugged to the raspi :RÉ also with lilly player on my iphone on airplay and music from my nas.
I have checked also bubble upnp and also working.
It is a verygood improvement from HIfiberry os team and we could thank them for this : en haut:
New release 20200708:
- Added Music browser to handle local music libraries
- New 96kHz DSP profiles for DAC+ DSP and DSP add-on board
- Several other bugfixes and improvements
- 20200706: several bug fixes
- 20200708: bugfixes in SMB mount
Releases * hifiberry/hifiberry-os * GitHub
@hopkins
I got this working myself some time ago, but can't remember what I changed in order prevent the USB-DAC from disappearing. If I can find the time I'll try to find my solution during the weekend. (I'm not using this image at the moment, so need to set it up again).
- PC Based
- Hifiberry OS - did some one use it
