PC Based Computer music servers, crossovers, and equalization
optical SFP multichannel transport
Old 31st August 2019, 12:37 PM   #1
Asasl is offline Asasl
Default optical SFP multichannel transport
Hi hobby colleagues!
I have long planned to develop and assemble a multi-channel audio system based on fiber optic connections.
Now optical SFP modules are inexpensive.
I know electronics well, PCB in Eagle,
writing in C and Python language, including for microcontrollers. I know the DSP, but only in theory. Never wrote for FPGA.
Join the open-project, especially FPGA specialists are needed.
Mono module 60 W
Old 31st August 2019, 07:36 PM   #2
phofman is offline phofman  Czech Republic
I see master clock at the XMOS. Would the remote units use PLL for clock recovery from the incoming stream? In that case why not use regular TOSLINK for the transfer?
Old 31st August 2019, 08:23 PM   #3
No PLL on remote devices will be used. The master clock is transmitted in the common TDM stream, the jitter of the SFP modules is very very small...
TOSLINK cannot transmit 8 channels 24 x 192 kbis/s x 8 ch = 36,864 Mbit/s
via SFP 1Gb, 200 such channels can be transmitted or over 60 channels 32x384 kbit/s
TOSLINK it's already yesterday.
SFP optics are much faster and cheaper, I wrote the prices in the figures
TDM frame for example
Old 31st August 2019, 10:36 PM   #4
Interesting. I know almost nothing about the SFP technology. How does it technically route audio clock through a switch without introducing any jitter/phase delays?
Old 1st September 2019, 08:57 AM   #5
Output / Input jitter SFP
For 1Gb interface jitter less than 200 ps
for perfectionists, you can take 10 Gb modules - 20 ps
Here's an example of what you can do for music and film
Old 1st September 2019, 09:46 AM   #6
OK, no switch, but splitter. Still I do not understand - can you run the SPF line at any frequency you want, or does it support just a set of fixed frequencies you can switch between?
Old 1st September 2019, 10:11 AM   #7
it is possible at any frequency in a certain band, for example 100 MHz - 1 GHz
The module does not know anything about this.
What came from the differential input LVPECL went to the laser and vice versa...
Old 1st September 2019, 11:43 AM   #8
Thanks. IIUC the rate-select pin should switch the module to lower freq support, depending on params of the given module converter - SFP pin requirement - Electrical Engineering Stack Exchange
That jitter is comparable to decent SPDIF receiver https://statics.cirrus.com/pubs/whit...ansceivers.pdf
Old 1st September 2019, 12:08 PM   #9
I indicated the above values jitter tolerance. For SFP is equal 0.2 UI
For TOSLINK 0.2 UI
real jitter SFP will be much smaller - about 10 ps
Jitter is inversely proportional to the maximum channel transfer rate !!!
SFP module can be set/read parameters via bus I2C...
Old 3rd September 2019, 05:29 PM   #10
CharlieLaub is offline CharlieLaub  United States
I see you using this image to represent jitter in your system:
I assume this is supposed to be a digital signal, alternating between high and low? Only at the very bleeding edge of what sample rates can be supported would such "rounding" occur...
I really do not think that picture of jitter in a digital audio signal area really all that applicable to the "real" world, and if so they would only be a of concern where the digital audio is rendered via a DAC. This is under the assumption that the bandwidth of the signal transmission system is more than capable of carrying such a signal, and that the digital signal is not being bandlimited elsewhere. At what frequency do you expect to see such a pattern?
Would not a simple buffer and re-clocker at the DAC end of the chain make all of this a moot point ?
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
optical SFP multichannel transportHide this!Advertise here!
DIY transport w/ CDROM drive vs player as transport dw1narso Digital Source 8 17th April 2016 07:14 PM
line to optical ---> optical to analog dirtbiker1824 Digital Line Level 6 15th October 2014 07:17 PM
A new fully analog FM modulated wideband optical transport Open Standard. freax Analog Line Level 30 3rd December 2012 11:39 PM
Indexing gel for AT&T optical glass transport to dac link georgehifi Digital Source 2 4th June 2008 11:46 PM
DIY transport kit with optical output Salsero Digital Source 1 9th June 2003 11:03 AM
Copyright ©1999-2019 diyAudio
