PC Based Computer music servers, crossovers, and equalization
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Old 18th August 2019, 10:30 PM   #811
Greg Stewart is offline Greg Stewart  United States
@ernesternest,
See post #223 of this thread for a picture of the Mouser PN for some moderate ESR .33F/5.5V supercaps recommened by Joe Rasmussen and used by Allo in their Boss and Katana DACs (among other places). These are currently EOL, so either find a source with some in stock and get some soon or find the replacement.
Because they are not low ESR, the current inrush when power is applied is minimal.
Then on lower ESR Ultracaps, I got these different types from Mouser to try on Ian's DAC boards, though I haven't tried them yet:
Mouser #: 598-DGH155Q5R5
Mfr. #: DGH155Q5R5
Mfr.: Illinois Capacitor / CDE
Mouser #: 581-SCMR22C155MRBA0
Mfr. #: SCMR22C155MRBA0
Mfr.: AVX
Mouser #: 723-BMOD0001P005B02
Mfr. #: BMOD0001 P005 B02
Mfr.: Maxwell / Nesscap
My questions and comments along with others' responses in the past several posts are about using these low ESR Ultracaps with Ian's LiFePO4 supply... which I'm beginning to think is not a good idea unless some means is used to limit the charge current when the LiFePO4 supply is turned on or to pre-charge the low ESR Ultracaps before turning the supply on. Either can be done, but will take some work and care. I suspect just installing them without dealing with the likely VERY HIGH instantaneous charge current from the LiFePO4 cells could be disasterous!
Maybe someone else has tried this and can either let us know it works ok or warn us against it?
Greg in Mississippi
P.S. The low-ESR Ultracaps above are similar to those used by @Wlowes in his implementations of Ian's I2StoPCM board and FiFoPi, but since Walter is powering his setup with AC-connected supplies and a final LDO with built-in current limiting, he doesn't have issues with current inrush.
They are also similar to those used by Allo as the final output C in their Shanti power supplies.
Everything matters!
Old 19th August 2019, 03:03 AM   #812
ernesternest is online now ernesternest  Europe
ernesternest's Avatar
Thanks Greg, I will try to get some of the small ones with higher ESR. Was looking at Mouser yesterday without success. So I hope they are still available.
Cheers, Ernst
Old 19th August 2019, 03:22 AM   #813
Markw4 is offline Markw4  United States
Its easy to add a little ESR with a plain old R.
Old 19th August 2019, 06:10 AM   #814
Default EEC-S0HD334HN
Greg, meanwhile they are out of stock and discontinued :-( Maybe I can find another one somewhere....
Mark, yepp.
Ernst
Old Today, 12:31 AM   #815
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Greg I ran my dac board with 1.5f caps on the rails powered by lifepo board directly. They're avx scm caps, 580m ohm. No issues.
Old Today, 01:06 AM   #816
How many milli-ohms of resistance in the PCB traces, wiring, terminals, relay contacts, etc., between the batteries and the caps?
Old Today, 05:10 AM   #817
jimk04 is offline jimk04  United Kingdom
RS UK have the 0.33f Pana caps in. They have 2 versions ? Both SD series but one is Gold series?
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...Hide this!Advertise here!
Detailed specifics, hints and tweaks in designing a sealed sub Squeak Subwoofers 1 17th July 2015 03:27 PM
The latest tweaks :) lowtherdream Everything Else 6 13th January 2009 05:43 PM
S5 K-16LS mods, tweaks? hartze11 Tubes / Valves 3 1st December 2008 05:13 AM
NAD C541i: possible tweaks and mods? Karlosak Digital Source 4 23rd November 2006 06:20 PM
Any mods/tweaks for a Panasonic DVD S-49 mikee55 Digital Source 4 19th March 2006 07:04 AM
Copyright ©1999-2019 diyAudio
