PC Based Computer music servers, crossovers, and equalization
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Old 15th July 2019, 07:47 PM   #661
misterdog is offline misterdog  United Kingdom
Thank you, was it visible to you ?
Old 16th July 2019, 11:40 AM   #662
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by Supersurfer View Post
Here is the picture from misterdog.
Thanks Supersurfer,
That looks nice. I'll do some similar test soon.
Ian
Old 16th July 2019, 11:44 AM   #663
iancanada's Avatar
Thanks Supersurfer for the links?
Which is the best oscillator do you think?
I have some boards but I'm not sure if they are the finial version.
Ian
Old 16th July 2019, 12:59 PM   #664
wlowes is offline wlowes  Canada
wlowes's Avatar
If I understand correctly, the SC cut family. The best should be the 5mHz SC cut. It's spec beats all. PCB is under development. If listening to redbook, it should outperform all. We will have to wait for pcb to be finished and get listening reports from Supersurfer.
Old 16th July 2019, 04:36 PM   #665
diyiggy is offline diyiggy
Ian is hearing more ESs chips thanold pcm, but I assume having the previous boards of Anddea Mori, means he has some 45 to 48 at cut first that should beat easily both the ndk and crysteq.
If Ian I should try it first and then report.
Old 16th July 2019, 07:26 PM   #666
Supersurfer is offline Supersurfer  Netherlands
Ian
Wlowes said it correctly. I only build the 45mhz clock currently. I am waiting for the board for the bigger housing of the 5mhz sc-cut clock from Andrea.
Old 16th July 2019, 07:28 PM   #667
Yes, I have a google account, I do not know if this makes a difference.
Just downloaded your picture and reposted.
Old 17th July 2019, 03:21 PM   #668
TioFrancotirador is offline TioFrancotirador  Poland
Hi guys, finally someone did it! RPI is not needed with this if one wants to stream from computer.
USB-I2S (USB interface) beta test | HiFiBerry
Old 18th July 2019, 07:02 AM   #669
amigo1 is offline amigo1
amigo1's Avatar
Default which Beaglebone Black Linux OS is best?
Some user use BBB. Please tell, which Beaglebone Black Linux OS is best?
Old 18th July 2019, 11:45 AM   #670
iancanada's Avatar
That's a really interesting project. But I would be more interested in a solution that can switch between RPi and USB streamer.
Just hope it works with FifoPi and HATs above it.
Ian
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...Hide this!Advertise here!
Detailed specifics, hints and tweaks in designing a sealed sub Squeak Subwoofers 1 17th July 2015 03:27 PM
The latest tweaks :) lowtherdream Everything Else 6 13th January 2009 05:43 PM
S5 K-16LS mods, tweaks? hartze11 Tubes / Valves 3 1st December 2008 05:13 AM
NAD C541i: possible tweaks and mods? Karlosak Digital Source 4 23rd November 2006 06:20 PM
Any mods/tweaks for a Panasonic DVD S-49 mikee55 Digital Source 4 19th March 2006 07:04 AM
Copyright ©1999-2019 diyAudio
