PC Based Computer music servers, crossovers, and equalization
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Old 31st March 2020, 08:18 AM   #1321
farooqniaz is offline farooqniaz  Pakistan
Hi
A simple question to any one who has been using this completed DAC with output transformers and Ultra Capacitors.
Anyone compared with some other commercially available DAC
Old 31st March 2020, 10:32 PM   #1322
misterdog is offline misterdog  United Kingdom
Originally Posted by billyboyk View Post
Here is the pinout used to supply i2s to FIFOPI:
Wiring
Can anyone confirm if this pinout is correct please as I wish to split my stack.
Old 1st April 2020, 06:48 AM   #1323
billyboyk is offline billyboyk  France
I'm pretty sure it is OK, I manage to get signal in and out on the table. Unfortunately, after having put everthing in place in the final box, the clocks's led are flashing. I am trying to fix it with Ian.
Have a nice day !
Old 4th April 2020, 10:18 PM   #1324
sebbyp is offline sebbyp  United Kingdom
From memory that looks right.
You are only taking one ground though? I take ground for each signal cable and twist them into three pairs.
Old 5th April 2020, 09:57 AM   #1325
I confirm, the pinout is the right one, it works at home, I use coaxial cable with one shield connected to ground, expect for one the tree where both side is connected to ground.
Old 5th April 2020, 01:01 PM   #1326
Co-ax cable, nice idea! I may move to that too.
Do you have a photo of how you made it tidy with the shield?
Edit: did you use 75 ohm?
Old 6th April 2020, 09:30 AM   #1327
Grarea is offline Grarea  United Kingdom
Could I ask another basic question please?
I am so new to this.
I got a LifePo4, Pi 3B+ , Fifopi, transportpi, Khadas tone board.
Loving the difference from what i had before.
Can I please check I am wired up as optimally as I can for a basic set up.
II have read stuff, but don't understand all the words, let alone the inferences.
I am poweriing pi via fifopi from non-isolated 5v output on LifePo4.
Powering fifopi from isolated 3.3v
Powering KTB from USB from Pi.
Using Coaxal from transporterpi to KTB.
Then RCA to amp.
Thanks.
Old 7th April 2020, 04:32 PM   #1328
The Pi is a very noisy device, I would use the other non-isolated 5V from LiFeP04 as a minimum. The Pi has a shared USB/ethernet bus and DC switchers which will add noise to the supply of your KTB.
Better still use a separate super regulated supply for the KTB.
Old 7th April 2020, 05:13 PM   #1329
wlowes is offline wlowes  Canada
wlowes's Avatar
Agreed. Any good PS will be a step up.
I am not clear on how you feed signal to the DAC. It sounds like USB and then the DAC reclocks? If so it seems to not take advantage of FIFOPi. Perhaps I'm confused.
Old 7th April 2020, 05:24 PM   #1330
OK, thank you for that.
LiFePO4 only has the one non-isolated 5v, but can use one of the other isolated outputs.
I was vaguely wondering that.
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...Hide this!Advertise here!
Detailed specifics, hints and tweaks in designing a sealed sub Squeak Subwoofers 1 17th July 2015 03:27 PM
The latest tweaks :) lowtherdream Everything Else 6 13th January 2009 05:43 PM
S5 K-16LS mods, tweaks? hartze11 Tubes / Valves 3 1st December 2008 05:13 AM
NAD C541i: possible tweaks and mods? Karlosak Digital Source 4 23rd November 2006 06:20 PM
Any mods/tweaks for a Panasonic DVD S-49 mikee55 Digital Source 4 19th March 2006 07:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
