PC Based Computer music servers, crossovers, and equalization
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Old 19th February 2020, 11:09 PM   #1281
wlowes is offline wlowes  Canada
wlowes's Avatar
Originally Posted by soundcheck View Post
Ah. OK. Didn't realize you still live in the dark ages of manually toggling switches.
That's been another live on my side. Sorry for the ignorance.
I simply can't live with a DIY system based on "toggle-switches" (for every DC rail!)
or on-system control knobs anymore. No wonder you're leaving it on 24/7.
Enjoy.
Actually only two switches for many power supplies. Such engineering excellence... My music room also has many pot lights in the ceiling all turned all turned on at once with a single wall switch. Right out of the dark ages. It too is not dangerous, and I do not need a manual to turn the lights off.
Old 20th February 2020, 02:42 PM   #1282
randytsuch is offline randytsuch
Originally Posted by MikeyFresh View Post
Typo there, you meant 3a @ 5v
I leave mine on 24/7 too!
Good catch, thanks for the correction.
My system is here
randytsuch system
Old 20th February 2020, 03:17 PM   #1283
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Do they really draw 3A sat doing nuffink?
Old 20th February 2020, 06:44 PM   #1284
MikeyFresh is offline MikeyFresh  United States
MikeyFresh's Avatar
No not at all, though what the actual draw is will depend on what is connected, if you were to have all kinds of USB devices drawing bus power that obviously increases the load considerably.
The RPi foundation has specified use of a 3 amp power supply with the 4B board to allow for some wiggle room. I have booted the 4B using a 2.5 amp supply no problem, even with a USB bus powered DAC connected, there is no lightning bolt icon indicating a voltage sag due to excessive current draw.
If you were going to see that problem it would be during the initial boot sequence, when the most juice is required, or when too many power hungry devices are attached.
Old 20th February 2020, 08:27 PM   #1285
3A is a really conservative (high) estimate, I think, but it depends on your setup.
I have a passive (transformer) output stage. With an opamp output you might draw more current.
My system is here
randytsuch system
Old 26th February 2020, 11:50 AM   #1286
Lso is offline Lso
Default using a different DAC
I'm trying use a Aroiodac with the ReceiverPi in a RPI free mode, but ihave no audio out.
Is this combination possible? I suspect that the Aroiodac is a master DAC.
Old 2nd March 2020, 10:56 AM   #1287
sebbyp is offline sebbyp  United Kingdom
Originally Posted by misterdog View Post
Not if there is only a market for 10/30 boards with all the R+D time for Ian.
I would guess at a weeks work to design/prototype/populate/test/troubleshoot,
REV 1.1 repopulate test. At what $ 30/Hour + parts.
I would guess at least $ 200 more, if 20 people were still interested at that price.
Some will probably wish for dual DAC chips making the market smaller still.
I would be interested in the 200-300 USD range for a 2x single-chip AK4499 DAC boards and I have a few friends that would be too
I hope it is financially viable for Ian to do a design.
Old 2nd March 2020, 11:26 AM   #1288
misterdog is offline misterdog  United Kingdom
AK4499DM DAC基板
33,500 Japanese Yen equals
243.37 Pound sterling
Old 2nd March 2020, 11:30 AM   #1289
AK4499DM DAC基板
I have seen that Dac.
I am not sure a dual-mono build is required for the 4499, but a pretty good value board all the less
I'd be happy either for a single or dual-mono board from Ian.
Old 2nd March 2020, 12:15 PM   #1290
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Me too, even 400$
Once you listen to AK DAC you never go back! LOL
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | TGM8 | VZ Audio NS OPS | FC-100 | Modulus-686 |
DACs : Mirand AK4490 + Discrete Output | Ian Dual ES9038K2M | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...Hide this!Advertise here!
Detailed specifics, hints and tweaks in designing a sealed sub Squeak Subwoofers 1 17th July 2015 03:27 PM
The latest tweaks :) lowtherdream Everything Else 6 13th January 2009 05:43 PM
S5 K-16LS mods, tweaks? hartze11 Tubes / Valves 3 1st December 2008 05:13 AM
NAD C541i: possible tweaks and mods? Karlosak Digital Source 4 23rd November 2006 06:20 PM
Any mods/tweaks for a Panasonic DVD S-49 mikee55 Digital Source 4 19th March 2006 07:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
