PC Based Computer music servers, crossovers, and equalization
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
Old 13th February 2020, 07:36 PM   #1251
3kes is offline 3kes  Netherlands
Originally Posted by wlowes View Post
I have seen much discussion re pre charging supercaps. FWIW I will share my simple approach. I use 50F caps on the 5v supply to the Rpi. So much smaller than some I see here, but still a serious pair of caps. The PS is a simple linear CRC filtered linear supply regulated with the high amp version of the 7805. I put a heat sync on the 7805 consisting of a simple strip of brass. No problem with heat dissipation and no pre-charging required. Just flip the switch and it charges up in a few seconds and runs for weeks/months without issue. Great sound.
A picture of this setup would be highly appreciated
Old 13th February 2020, 07:41 PM   #1252
jimk04 is offline jimk04  United Kingdom
How does one know you are listening to that supercap and not the 7805 in this case?
Old 13th February 2020, 08:44 PM   #1253
randytsuch is offline randytsuch
Add a switch so you can disconnect the 7805 and decide if it makes a difference. But the caps need to be large enough to power your setup without help.
My system is here
randytsuch system
Old 14th February 2020, 03:36 AM   #1254
wlowes is offline wlowes  Canada
wlowes's Avatar
I like the quote... "everything counts". In this case it means you are listening to the 7805, the supercaps, the transformer, the diodes and the filtering caps. It is a good linear PS with a LM7805 and supercaps powering a computer. Beats a switching PS by a long shot, but certainly not perfect. Quite sufficient for the task. In an earlier life it powered a DAC that was well regarded on these forums and now it powers a computer. It is enough for me.
PS schematic below. Caps are now Panasonic. Smaller resistors. LM7805 follows, then 2x 50F supercaps feeding the Rpi.
Old 14th February 2020, 06:04 AM   #1255
Good information thankyou. Can I ask what 50F caps you use?
Old 14th February 2020, 07:46 PM   #1256
wlowes's Avatar
I use Nesscap ESHSR. 14mOhm.
ESHSR-0050C0-002R7 NessCap Co Ltd | Capacitors | DigiKey
Nesscap was one of the early innovators. I believe ultimately acquired by Maxwell. I worked for a tech startup that used millions of these in the PS for industrial wireless communications modules. So I had a bunch of these in my parts bin that have now found new life in my streamer. They are still available at Digikey. You will find the same thing with a Maxwell label as well.
Old 15th February 2020, 04:46 AM   #1257
nano35 is offline nano35  Hong Kong
So you simply parallel supercaps at the regulator’s output?
No special circuitry to control the caps?
2.7V supercaps for use at the RPi’s GPIO 5V pin?
I thought it will blow with lower than 5V voltage cap.
I did a similar thing with Two 2200uF/10V cape at the GPIO pin 4 and ground before; the improvement is quite noticeable. Harshness is greatly reduced and bass is more defined.
I really want to try supercaps if connection is simple.
Old 15th February 2020, 10:18 AM   #1258
misterdog is offline misterdog  United Kingdom
Originally Posted by nano35 View Post
2.7V supercaps for use at the RPiís GPIO 5V pin?
Ultracapacitor Example No1
A 5.5 volt, 1.5 farad ultracapacitor is required as an energy storage backup device for an electronic circuit. If the ultracapacitor is to be made from individual 2.75v, 0.5F cells, calculate the number of cells required and the layout of the array.
ultracapacitor voltage
The array will therefore have two capacitor cells of 2.75v each connected in series to provide the required 5.5v.
https://www.electronics-tutorials.ws...apacitors.html
2x 2.7V capacitors connected to each other in series then placed in parallel across the supply.
Old 15th February 2020, 01:07 PM   #1259
Thank you so much. Very clear explanation!
Old 15th February 2020, 02:18 PM   #1260
wlowes's Avatar
So you simply parallel supercaps at the regulatorís output?
Series connected yielding a 5.4v 25F cap. No additional circuitry. If you go beyond 2 series caps use balancing resistors to ensure even distribution across the caps.
IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...Hide this!Advertise here!
Detailed specifics, hints and tweaks in designing a sealed sub Squeak Subwoofers 1 17th July 2015 04:27 PM
The latest tweaks :) lowtherdream Everything Else 6 13th January 2009 06:43 PM
S5 K-16LS mods, tweaks? hartze11 Tubes / Valves 3 1st December 2008 06:13 AM
NAD C541i: possible tweaks and mods? Karlosak Digital Source 4 23rd November 2006 07:20 PM
Any mods/tweaks for a Panasonic DVD S-49 mikee55 Digital Source 4 19th March 2006 08:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
