PC Based Computer music servers, crossovers, and equalization
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux
Thread Tools
Old 19th February 2021, 05:08 PM   #901
von Ah is offline von Ah  United States
von Ah's Avatar
Geez, Mint is giving me trouble.
I tried allowing source code repositories, and Synaptic just hangs when it's 'Updating cache'
Old 19th February 2021, 05:32 PM   #902
von Ah's Avatar
Found a synaptic freeze solution...
[SOLVED] Software Sources stuck at "Updating cache" "Waiting for synaptic to exit" - Linux Mint Forums
Edit: It's working again after applying the fixes. I applied the hold.
Thanks for your help.
Old 20th February 2021, 02:13 AM   #903
Tfive is offline Tfive  Germany
Tfive's Avatar
very interesting. I swear my old laptop didn't need the fixes. no chance i'll try it on my living room pc atm (it's my server/nas) and the "new" laptop is currently down due to cocktail in the keyboard. the replacement is still not delivered :/
Want more of the good stuff? -> https://t-5.eu/
Old 26th February 2021, 05:17 PM   #904
xorcz is online now xorcz  Czech Republic
If you are going to make GUI for CamillaDSP, I found this SW (EKIO) has two interesting features:
- import of measurement files
- A x B button to test two crossovers (filter combinations)
The first is probably complicated, but would help to visualize the need of off-axis tuning.
Old 26th February 2021, 05:54 PM   #905
Tfive's Avatar
Plesse hit the bug/feature tracker at gitlab. Otherwise no guarantee the it will not get forgotten.
Old 26th February 2021, 07:46 PM   #906
kennyhorn is offline kennyhorn  Canada
I installed this and everything seems to be working as it should. I had one question though. Will a usb dac work the same as a soundcard or are you just stuck with whatever dac is in the soundcard you use.
Old 26th February 2021, 09:32 PM   #907
Tfive's Avatar
Everything that appears as a soundcard - and a USB DAC will do just that under Linux - will work as output device. At least it should
Old 26th February 2021, 09:33 PM   #908
Awesome thanks.
Old 26th February 2021, 09:34 PM   #909
Tfive's Avatar
In an attempt to clarify: I currently use a focusrite scarlett 18i20 USB device, works out of the box without any problems.
Old 27th February 2021, 10:17 AM   #910
I saw those on amazon. A bit pricey for me though .
I do have another question though. I intended on using this setup with my rpi. Once I had it all set up i realized I had hit a roadblock. I stream tidal. Has anyone figured out a way to do this? I assumed the tidal web player would work on linux. It doesnt. The only way I have found to do it is with plex. However the cost of the plex subscription on top of the tidal subscription is a bit much $$.
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linuxHide this!Advertise here!
Thread Tools
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 28 22nd November 2020 05:32 PM
analyzing my Linux/ecasound dsp crossover speaker system gibbyj Multi-Way 5 6th August 2017 07:42 PM
Linux + MPD player + dsp crossover via ecasound jplesset PC Based 11 15th September 2013 10:24 PM
Active Crossover using PC and multi ch. Soundcard? vision Digital Source 22 7th July 2012 11:59 PM
Implementation of 3 ways speaker with digital crossover ackcheng Multi-Way 4 6th December 2010 03:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
