PC Based Computer music servers, crossovers, and equalization
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux
Thread Tools
Old 17th February 2021, 09:07 PM   #891
DarpMalone is offline DarpMalone  Canada
DarpMalone's Avatar
Sounds like an easy choice so far. Any drawbacks to CamilaDSP backend?
Old 17th February 2021, 09:14 PM   #892
Tfive is offline Tfive  Germany
Tfive's Avatar
As I mentioned - kind of yes, if you want to incorporate LADSPA effects plugins. Those are out of the game completely when using camilla DSP. IMO no drawback at all, After all it's pulseaudio crossover rack and not pulseaudio effects rack
So far the consensus seems to be to go with camilla. I'll be thinking about a 2.0 then... No promises as to how and when though
Want more of the good stuff? -> https://t-5.eu/
Old 17th February 2021, 09:44 PM   #893
Tfive's Avatar
I just upgraded my old laptop to linux mint 20.1 and I'm happy to report that now the pulseaudio 13.99 fix found it's way upstream. First time that mint ships with a pulseaudio version that has hq resampling with soxr enabled and doesn't crash when using pulseaudio crossover rack.
Highly recommended upgrade!
Old 18th February 2021, 12:07 AM   #894
von Ah is offline von Ah  United States
von Ah's Avatar
Unfortunately, after the upgrade, PaXoR locks up when I load the filter modules.
I ran the unhold script before upgrading to 20.1.
Do I need a fresh install of PaXoR after upgrade?
Old 18th February 2021, 12:59 AM   #895
b_force is offline b_force  Europe
Originally Posted by Tfive View Post
Thanks for the praise
Currently I don't plan to add any effects. It's a crossover software not an effecs processor
Which effects are the most important for you?
For me personally is the bass enhancer effect.
(perfect for bluetooth devices or subwoofers systems)
FIR would be nice, but not really mandatory.
Even totally fine if one can just work with "FIR blocks" (load in data from 3rd party programs like rephase)
Other very welcome effect is some kind of compressor.
Ideally both being able to fit anywhere in the crossover chain, but I am aware I am being very picky right now
Maybe it's possible just to implement VST plugins instead?
Just brainstorming.
Old 18th February 2021, 01:13 AM   #896
Originally Posted by Ivo View Post
The GUI is what attracts me to paxor, I have no opinion about what goes on behind IT. I will say that LADSPA plugins and pulseaudio have worked welk for me and my hardware. I haven't been following the Camilla DSP thread, so I don't know what it is based on and whether it runs well on Raspberry Pi's. It's likely my media PC will continue to be pi's, and even likely my future desktop PCs will also be pi's.
Same here, I have been following it for a while, but lost my interest since it doesn't seem to get anywhere from an user point of view (no offence btw!!!!)
It's easier for me to set up a DSP in SigmaStudio otherwise.
Just the implementation with a Pi is super nice
Only wish it was easier to get muli-channel out on a Pi
Old 18th February 2021, 08:38 AM   #897
Tfive's Avatar
No, no changes necessary to PaXoR. Can you please try to apply the sink fixes again ( Jurgen Herrmann / pulseaudio_13.99_sink_fixes * GitLab ) - if that helps I'll have to investigate further.
Old 19th February 2021, 04:40 PM   #898
von Ah's Avatar
now I can't run the sink fixes...
./build.sh: line 1: syntax error near unexpected token `newline'
./build.sh: line 1: `<!DOCTYPE html>'
Old 19th February 2021, 04:49 PM   #899
Julf is offline Julf  Europe
Feeding a html document to the shell?
Old 19th February 2021, 04:50 PM   #900
Tfive's Avatar
Yes, i think you tried to download the single file from gitlab. Try downloading the whole repo as zip.
Pulseaudio Crossover Rack - multi-way crossover design &amp; implementation with linuxHide this!Advertise here!
Thread Tools
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 28 22nd November 2020 05:32 PM
analyzing my Linux/ecasound dsp crossover speaker system gibbyj Multi-Way 5 6th August 2017 07:42 PM
Linux + MPD player + dsp crossover via ecasound jplesset PC Based 11 15th September 2013 10:24 PM
Active Crossover using PC and multi ch. Soundcard? vision Digital Source 22 7th July 2012 11:59 PM
Implementation of 3 ways speaker with digital crossover ackcheng Multi-Way 4 6th December 2010 03:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
