PC Based Computer music servers, crossovers, and equalization
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux Please consider donating to help us continue to serve you.
Old 4th December 2019, 08:33 PM   #551
phofman is online now phofman  Czech Republic
Usually pip is for python2 (2.7?) while pip3 is for python3. If you install library with pip for python2, it will not be available for python3 since it is basically a different language. Ugly big mess in python :-(
Old 4th December 2019, 09:56 PM   #552
dave4 is offline dave4
Cheers, so would I be better reinstalling the OS and starting from scratch?
Old 5th December 2019, 06:05 AM   #553
Reinstalling OS is the windows way. The python2/python3 libraries are installed to different locations, independent of each other. Just install them for python 3 (pip3).
Old 6th December 2019, 09:26 AM   #554
Ahhh, I didnt see your message until I reinstalled Linux Mint 19.2 MATE.
It STILL gives the same errors though and cant install ZODB.
I did however see the following errors during the repository install
Code:
rr:10 ftp.cixug.es tina Release
  Could not connect to ftp.cixug.es:80 (193.144.61.75). - connect (111: Connection refused) [IP: 193.144.61.75 80]
Reading package lists... Done
E: The repository 'http://ftp.cixug.es/mint/packages tina Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
 N: See apt-secure(8) manpage for repository creation and user configuration details.
Is this relevant? Could anyone help me solve this?
As my linux knowledge is limited I don't really understand what else to do.
Old 6th December 2019, 10:56 AM   #555
... The python2/python3 libraries are installed to different locations, independent of each other. Just install them for python 3 (pip3).
phofman, I'm not altogether sure what you meant by libraries so I have installed PIP3 as follows -
Code:
q@q:~$ sudo apt install python3-venv python3-pip
Building dependency tree
Reading state information... Done
python3-pip is already the newest version (9.0.1-2.3~ubuntu1.18.04.1).
The following NEW packages will be installed:
  python3-venv python3.6-venv
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 7.388 B of archives.
After this operation, 44,0 kB of additional disk space will be used.
Get:1 Index of /ubuntu/archive bionic-updates/universe amd64 python3.6-venv amd64 3.6.9-1~18.04 [6.180 B]
Get:2 Index of /ubuntu/archive bionic-updates/universe amd64 python3-venv amd64 3.6.7-1~18.04 [1.208 B]
Fetched 7.388 B in 0s (48,8 kB/s)
Selecting previously unselected package python3.6-venv.
(Reading database ... 346184 files and directories currently installed.)
Preparing to unpack .../python3.6-venv_3.6.9-1~18.04_amd64.deb ...
Unpacking python3.6-venv (3.6.9-1~18.04) ...
Selecting previously unselected package python3-venv.
Preparing to unpack .../python3-venv_3.6.7-1~18.04_amd64.deb ...
Unpacking python3-venv (3.6.7-1~18.04) ...
Setting up python3.6-venv (3.6.9-1~18.04) ...
Setting up python3-venv (3.6.7-1~18.04) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
I used the instructions from this website - Installing pip/setuptools/wheel with Linux Package Managers — Python Packaging User Guide
Is this what you meant? If you could show me exactly what I need to do I will be very happy!
Old 6th December 2019, 11:22 AM   #556
By libraries I mean the packages installed by pip.
So no you have pip3 (pip for python3) installed. Since your error log complained about missing wheel, I would also install package python3-wheel.
Then you can try installing the packages required for paxor, using pip3
pip3 install ZODB
I am no python dev, just this procedure usually worked in my rare cases of using python.
Old 6th December 2019, 11:49 AM   #557
Many thanks for your explanations and swift reply!
That worked perfectly and paxor has started, thanks again for all your help!
Old 6th December 2019, 12:09 PM   #558
Congrats. And you have learned the principles at the same time.
Python3 has brought lots of useful features (python2 is a very ugly language, python3 just ugly :-) ), but its incompatibility with python2 (neither backward nor forward compatibility) causes huge mess in the python ecosystem as well as in linux distributions. Some tools assume the default /usr/bin/python symlink is python2, the newer ones expect python3. The years-old mess will stay for more years to come, lots of projects are still python2 only (e.g. the wonderful audio server mopidy).
Old 7th December 2019, 09:38 AM   #559
Julf is offline Julf  Europe
Yes, we should stop talking about "python" and always be clear use "python2" and "python3".
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linuxHide this!Advertise here!
analyzing my Linux/ecasound dsp crossover speaker system gibbyj Multi-Way 5 6th August 2017 08:42 PM
Linux + MPD player + dsp crossover via ecasound jplesset PC Based 11 15th September 2013 11:24 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 06:59 AM
Active Crossover using PC and multi ch. Soundcard? vision Digital Source 22 8th July 2012 12:59 AM
Implementation of 3 ways speaker with digital crossover ackcheng Multi-Way 4 6th December 2010 04:50 PM
Copyright ©1999-2019 diyAudio
