PC Based Computer music servers, crossovers, and equalization
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux
Old 5th December 2018, 06:46 PM   #31
dukanvadet is offline dukanvadet
This might be exactly what i want, if i understand it correctly this is system wide so anything that outputs trough pulseaudio is filtered? Can you add latency on a channel? Is there any latency inherent in the filtering?
One feature that would be nice is if you could import a frequency response and see the changes directly on the curve. Not that necessary or important but would be nice
Old 5th December 2018, 07:06 PM   #32
Tfive is offline Tfive  Germany
Tfive's Avatar
Yes, this is system-wide as the input sink of PaXoverRack is set as default sink.
AFAIK there is no latency induced by filtering itself as all the pulseaudio buffers have to be handed around anyways and the simply get put through all LADSPA sinks additionally.
Yes, you can add a latency to a path by adding a (sub)sample delay.
Not sure what you mean by "import a frequency response" though. Hint: you can show the overall frequency response of the filter chain on an output.
Old 5th December 2018, 09:04 PM   #33
Sounds good! What i meant was to load a measured frequency response as .frd file and see the changes on that kinda like in most passive crossover simulators.
Old 5th December 2018, 09:45 PM   #34
Tfive's Avatar
OK, will think about that. It probably only makes sense to compare the .frd to the inverse eq curve of a specific parametric eq as you wouldnt want to compare it to adjustments already made and inserted when measuring that frequency response, correct? So then you could adjust the eq so that the combined .frd and inverse eq FR would yield a flat frequency response...
Old 9th December 2018, 03:46 PM   #35
theSuede is offline theSuede  Sweden
Originally Posted by Tfive View Post
Another update: I'm struggling hard to find a formula to calculate the IIR filter coefficients for a third order Butterworth filter. Anybody here who can help with this?
I'm searching for something like:
Code:
    def _coeffsBA(f, samplerate):
        """ return 12db/oct high pass biquad coeffs for given frequency """
        w0 = 2 * pi * f / samplerate
        alpha = sin(w0) / 2 / 0.7071067811865476 # Butterworth characteristic, Q = 0.707...
        cs = cos(w0)
        norm = 1 / (1 + alpha)
        b0 = (1 + cs) / 2 * norm
        b1 = -1.0 * (1 + cs) * norm
        b2 = b0
        a1 = -2 * cs * norm
        a2 = (1 - alpha) * norm
        return (b0, b1, b2), (1, a1, a2)
In the meantime I'm trying my luck with some DSP literatur but my head is already aching like hell!
I think this would be a good place to start - it's good to understand the basics and not just "plug in" values from a chart....
Design IIR Butterworth Filters Using 12 Lines of Code - Neil Robertson
There's some (quite) easy to read Matlab code in the appendix at the bottom of the page.
But the odd order Butterworth filters are generally easiest to think of as the even order BW filter one step lower multiplied by the product of a first order BW filter (5th order = 4th order x 1st order and so on).
First order = 1+s
Second order = 1+1.414s+s^2
Third order = (1+s)(1+1.414s+s^2)
I think that would give
a = [1, -2.0286, 1.4762, -0.3714]
b = [1, 3, 3, 1]
Old 10th December 2018, 04:03 PM   #36
Tfive's Avatar
Originally Posted by theSuede View Post
First order = 1+s
b = [1, 3, 3, 1]
Would you care to elaborate what "s" refers to?
Old 18th December 2018, 05:25 PM   #37
Tfive's Avatar
FWIW I still am trying to figure out how to calculate the damn filter coefficients for 3rd order filters. I reverse engineered the code of butter() in scipy.signal, simplified it for the case of N=3 (3rd order) and tried to implement it in C. Here's the preliminary result:
[C] #include <math.h> #include <stdio.h> #include <stdlib.h> #include <string.h> - Pastebin.com
What I still need to figure out how to emulate numpy.poly() in this case, which takes the zeroes of a polynomial function and returns the coefficients of it. Any chance sombody knows about this stuff?
Old 19th December 2018, 12:39 PM   #38
Tfive's Avatar
Update: somehow I figured out, how to calculate third order filter coefficients and I just released version 1.8 which adds second and third order butterworth low/high pass filters together with a number of small bug fixes and the corresponding ladspa-t5-plugins 1.4 package.
Have fun!
Old 19th December 2018, 04:53 PM   #39
DRONE7 is offline DRONE7  New Zealand
Hoping for some time over the festive break to try on a Pi..
Old 31st December 2018, 09:02 AM   #40
morgot9999 is offline morgot9999  Romania
morgot9999's Avatar
Thumbs up Respect!
Wonderful project!
Can be extended to a 4 way design?
My future project is a 3-way active full-range speaker plus 1 or 2 subs.
Thinking to use a 7.1 soundcard with this kind of digital crossover
Pulseaudio Crossover Rack - multi-way crossover design &amp; implementation with linuxHide this!Advertise here!
analyzing my Linux/ecasound dsp crossover speaker system gibbyj Multi-Way 5 6th August 2017 07:42 PM
Linux + MPD player + dsp crossover via ecasound jplesset PC Based 11 15th September 2013 10:24 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Active Crossover using PC and multi ch. Soundcard? vision Digital Source 22 7th July 2012 11:59 PM
Implementation of 3 ways speaker with digital crossover ackcheng Multi-Way 4 6th December 2010 03:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
