PC Based Computer music servers, crossovers, and equalization
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux
Old 27th November 2018, 10:54 AM   #21
Tfive is offline Tfive  Germany
Tfive's Avatar
I just released version 1.5 with a small bugfix that prevented the realtime parametrization of SubsampleDelay from working correctly.
Old 27th November 2018, 02:40 PM   #22
tthorsten is offline tthorsten  Germany
will there be an DRC Digital Room Corretion implementen like in Accourate - or in the MINIDSP Projekt with FIR filters ?
Old 27th November 2018, 03:00 PM   #23
Tfive's Avatar
Somebody already asked this question via PM. What exactly do you need for this? It would probably be relatively easy to add a FIR convolver plugin where impulse responses could be configured by loading some kind of PCM impulse response file (WAV or similar). Would this be enough for your needs?
Old 27th November 2018, 11:43 PM   #24
DRONE7 is offline DRONE7  New Zealand
Originally Posted by Tfive View Post
Does that mean you'r listening to a speaker crossed over py PaXoverRack? If so, you're definitely first, man. My SCS4s are still lurking in the basement and I will have to build a 6 channel amp first to get my setup going...
If you want you can take a picture of your test setup and I will post it on the homepage as first ever system running on PaXoverRack
I'm still testing..... I've always been an Alsa user so Pulseaudio is a bit of a learning curve... The usb card I am using has no controls in Alsa but is configured correctly by pulseaudio..(Sound Blaster X-Fi Surround 5.1 Pro)
Finally found why I was getting all sorts of thumps and pops, why the card turned off when music stopped playing and why I was constantly having to redo the config as it defaulted to internal speakers after resuming from suspend....
TLP.... damn laptop power-saving....grrr..
Edited /etc/default/tlp and changed enable from 1 to 0
Card stays on now and suspend/resume works fine.
My basic testing is with small powered speakers (such as for use with ipod or mp3 player) as the satellites and a small home theatre powered sub for the mono woofer. So, yes a system running on PaXoverRack though a most meagre and basic one just for trying all the features.
Next the workshop big system using Kef satellites with Quad amp and a Monitor Audio sub (Silver W-12 | Subwoofer | Monitor Audio)
Once that's running I'll post some pix.
Old 28th November 2018, 10:03 AM   #25
Tfive's Avatar
Never heard of TLP. It seems interesting though, maybe i will try it for my laptop as well. From what i read you can disable the audio power saving feature separately. On the other hand, never change a running system
Old 28th November 2018, 07:00 PM   #26
The audio powersaving I think only supports Intel HDA, AC97.
I tried that first but no joy so just took the blunderbuss option and turned tlp off.
Thinking further it probably is the tlp usb auto-suspend that is playing havoc with the soundcard.
When I have a moment I will turn tlp on and disable the auto-suspend for the usb souncard and see if that works.
Question...any chance of a third-order filter 18db/octave for the Xover-rack ?
cheers,
bob
Old 28th November 2018, 07:15 PM   #27
Tfive's Avatar
cheers,
bob
I guess you're talking about 3rd order Butterworth? Implementing filters is relatively easy, so by the time i find out how to calculate biquad coefficients for them (I'm still a DSP noob) this should be no problem.
Old 29th November 2018, 11:28 AM   #28
Tfive's Avatar
After some reading I have to admit that there is a design mistake I made in the LR-2 low/highpass filters. these are not LR-2 characteristic as announced but effectively are second order Butterworth filters with -3dB gain at the crossover frequency and not -6dB as they should have. LR-4 filters are two 2nd order Butterworth filters in series and are thus implemented correctly. I will correct these mistakes in the next release and I will also add 2nd and 3rd order Butterworth filters to the mix.
Old 29th November 2018, 08:20 PM   #29
Tfive's Avatar
Update: 1.7 was released together with ladspa-t5-plugins 1.3 which fixes the wrong filter characteristics of the LR-2 filters. 2nd order and 3rd order butterworth filters will likely come tomorrow, the code base of the ladspa plugins has been reworked and cleaned up big time in preparation for these.
Old 2nd December 2018, 06:10 PM   #30
Tfive's Avatar
Another update: I'm struggling hard to find a formula to calculate the IIR filter coefficients for a third order Butterworth filter. Anybody here who can help with this?
I'm searching for something like:
Code:
    def _coeffsBA(f, samplerate):
        """ return 12db/oct high pass biquad coeffs for given frequency """
        w0 = 2 * pi * f / samplerate
        alpha = sin(w0) / 2 / 0.7071067811865476 # Butterworth characteristic, Q = 0.707...
        cs = cos(w0)
        norm = 1 / (1 + alpha)
        b0 = (1 + cs) / 2 * norm
        b1 = -1.0 * (1 + cs) * norm
        b2 = b0
        a1 = -2 * cs * norm
        a2 = (1 - alpha) * norm
        return (b0, b1, b2), (1, a1, a2)
In the meantime I'm trying my luck with some DSP literatur but my head is already aching like hell!
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linuxHide this!Advertise here!
analyzing my Linux/ecasound dsp crossover speaker system gibbyj Multi-Way 5 6th August 2017 07:42 PM
Linux + MPD player + dsp crossover via ecasound jplesset PC Based 11 15th September 2013 10:24 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Active Crossover using PC and multi ch. Soundcard? vision Digital Source 22 7th July 2012 11:59 PM
Implementation of 3 ways speaker with digital crossover ackcheng Multi-Way 4 6th December 2010 03:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
