PC Based Computer music servers, crossovers, and equalization
Getting the best out of Allo.com's new Katana DAC...
Old 12th March 2020, 03:18 PM   #431
BGSputnik is offline BGSputnik  Singapore
Originally Posted by newpeter View Post
This review has the information that KATANA sounds better without an isolator. Can you confirm or deny it ?
https://darko.audio/2019/09/allos-katana-player-shanti-power-supply/
Does anyone know why KATANA is not available on Allo.com ?
Hi I was wondering the same thing, why is KATANA not available on their website. I noticed that you posted this already last year and nothing has changed.
I wrote to them but received no reply.
Anybody has any idea and suggestion where to actually buy ?
Old 12th March 2020, 04:09 PM   #432
jonners is offline jonners  United Kingdom
jonners's Avatar
Shanti Dual LPS 5V/3A , 5V/1.5A
Old 12th March 2020, 04:54 PM   #433
Hi I am planning to build my own PSU for the DAC (connected to Pi3B). Possibly using the LT3042 on the positive rail to the OpAmps. My Question is this: I am planning to use batteries to feed into the linear power supply and when the batteries are getting low to switch to a second pack while charging the first ones. When I look at the specs of the LT3042 with 0.8uV ripple I wonder if the solution with the batteries with all its controls and charging technologies is actually providing any enhancement. I would achieve decoupling for the Mains but does that really reduce noise to the DACs when I use such a good control chip (LT3042) ?
Old 12th March 2020, 05:52 PM   #434
misterdog is offline misterdog  United Kingdom
The Shanti claims noise of 0.08 uV and costs less than you would pay for parts. Super caps on the output and very low impedance.
Shanti Dual Linear Ultra Low Noise PSU
Old 15th March 2020, 07:14 AM   #435
Default Allo Revolution power requirements
Originally Posted by Greg Stewart View Post
@altsouza,
You are very welcome. By going to a 4-supply setup with your Katana, you now have some seriously good sound... as good as a Katana is with a 2-supply setup, in my experience there is a very large jump when you go 4-supply with good +-15V supplies. Pity that most Katana users won't ever experience this level of goodness!
Allo's Revolution is a USB-input DAC and not at all compatible or interchangeable with the Katana. Will it be better? Allo learned a lot of new tricks in developing the Katana and has added a number of additional tricks since and will apply them liberally on the Revolution. BUT the Revolution will have less flexibility in providing it good power. AND it will be a significantly less expensive DAC, which tells you a bit about how Allo is positioning it.
AND of course, the quality of your USB source will matter too, just as RPi power and your operating conditions matter. The Revolution will be a natural mate to Allo's new USBBridge Signature... which should also work VERY well under a Katana. I have a couple of RPi 2B's that I've modified to replace the on-board DC-DC converters for the 3.3V and 1.8V and they are a significant jump in SQ over an unmodified RPi when used as an I2S source. I suspect the USBBridge Signature might be as large of a jump over my modified RPis.
Allo did answer the same question in the larger Shanti / Revolution thread:
I really can't add anymore to what he said!
Greg in Mississippi
Hello Greg,
I am in the midst of designing my streamer and initially thought of using the Katana board. However since the Revolution seems to be around the corner I decided to wait and focus on the power supply development for the time being.
Could you share with us what power requirements the Revolution board will likely need (voltages, and currents)?
Could you share with us when the board will be likely available ?
Highly appreciated, Bjoern
Old 15th March 2020, 11:11 PM   #436
Rev will come in a alu box with oled screen.Psu , remote and cable will be sold separately.
Shanti Dual LPS 5V/3A , 5V/1.5A This is also the Revolution thread.
Allo claim their Shanti LPSU is only a shade better than their SMPS. The Shanti is very good, I have one.
IIRC Allo have said the only power for the Revolution DAC is 1x 5V supply.
As I see it Allo have designed it as a plug and play USB DAC rather than aiming at the DIY sector.
Old 6th April 2020, 10:10 PM   #437
sp33ls is offline sp33ls
I'm assuming that the Katana would still be a notch above the Revolution tho?
Old 6th April 2020, 10:37 PM   #438
wannarock2 is online now wannarock2
See link
cdsgames is in the know. I just hope that in the future Allo will offer the kit of materials for the new Rev for Wifi, Volumio ... well exactly like Katana
Old 16th May 2020, 11:06 PM   #439
Originally Posted by wannarock2 View Post
See link
so, i think iím just now catching up ..
the next Allo premium streaming arrangement would be ..?
USBridge Signature Player <> Shanti <> Revolution DAC
Old 16th May 2020, 11:49 PM   #440
kevinkr's Avatar
I have a USBridge Signature running Ropieee (Roon endpoint) and a Shanti supply. Quite pleased with overall performance with a Topping DX7s Dac.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Getting the best out of Allo.com's new Katana DAC...Hide this!Advertise here!
Allo Digione pistollero Swap Meet 9 13th December 2018 08:05 PM
FS - Inca Design Katana SE CD Player powershot Swap Meet 1 27th February 2011 09:05 PM
Inca Design Katana problem.. audio1st Digital Source 6 26th October 2007 12:50 PM
Allo Allo! ianpengelly Introductions 5 30th October 2006 08:31 AM
Allo All BraClay Introductions 5 9th January 2003 03:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
