PC Based Computer music servers, crossovers, and equalization
Help me figure out a Raspberry Pi interface
Old 27th September 2018, 02:28 AM   #1
Pibuilder2018 is offline Pibuilder2018
Question Help me figure out a Raspberry Pi interface
I'm thinking I'd like to build a Raspberry Pi device with a 7in touchscreen for my home stereo, to stream music.
2 key things:
1. I don't have Spotify premium. Is the only way to have Spotify without premium using Chromium on Raspbian, in this way:
How to listen to Spotify on the Raspberry Pi - The Pi
2. Related question, I'd like to have quick access to BBC Radio 1, which streams on their website. Would the best way involve using a browser window for this too? (There is an Android app)
3. Would it be worthwhile to have a Raspbian/Max2Play/Rune audio/Pi Musicbox multiboot involving 2 or more? Which ones?
Old 27th September 2018, 12:11 PM   #2
CharlieLaub is offline CharlieLaub  United States
I have used:
MPD - can do streaming audio or local files. Has remote interface (see below)
R-Pi - headless, does the audio processing
USB pro audio interface - these will also have a good quality analog input as well as DACs
10" Android tablet - I use this in lieu of a monitor on the Pi. It runs the remote interface for MPD
Why have a tethered interface when all you need is to control the audio? Instead look for a player or system with remote interface capability. The tablet is just another WiFi connected device on my network, and it connects to the MPD instance running on the Pi. You can control content and playback volume, and can do this from whereever you have WiFi coverage. If the phone rings and you are in another room you can quickly mute the audio to answer the call instead of having to run back to the stereo system.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 28th September 2018, 12:32 AM   #3
Indeed, remote interface capability would definitely be a plus here...so wouldn't a Remote Desktop app presumably for Raspbian (unless a multi/dual-boot option is advised) work?
Old 28th September 2018, 02:16 AM   #4
drneilmb is offline drneilmb  United States
If you want a remote interface, then I think that the picoreplayer OS and a separate Logitech Media Server box is a great solution. Picoreplayer has a touchscreen interface that can be installed on the Pi, but it also offers complete headless control from ios, Android, and PCs.
I originally thought that LMS and PiCorePlayer were going to be ridiculous overkill for what I wanted, but after trying it out, I'm a convert. The full client-server model is just so flexible that whatever you want to do is already built in. Heck, I use it in my office so that I can control playback from my computer on the system on the other side of the room.
Personally, I plan to use a cheap tablet for the UI and keep the Pi just as a headless streamer, but the touchscreen is a reasonable solution if you've already got one. My research found that an old android tablet for $30 is much cheaper than the RPi touchscreen and a case that can hold it.
There are LMS plugins for Spotify, but they do require you to have premium. You aren't going to get free Spotify on anything but the browser or PC apps.
BBC Radio 1 is in the internet radio directory of LMS already.
-Neil N0FN
Old 28th September 2018, 10:26 PM   #5
randytsuch is offline randytsuch
I know picoreplayer supports a tidal app. So if you had tidal, you just just a pi/dac setup, and then something to control it with, phone, laptop or a pad.
I don't have spotify, so not sure if there is something on picoreplayer that supports spotify.
The nice thing about pcp and some of these other solutions is they are free, so you can download to a pi and try them out, and see if they work for you.
Everyone is different, so it's hard to judge a user interface without trying it.
I wrote this up when I was trying out different stuff, and I didn't finish it all, but it should help you get started
pi software
I ended up never doing the multi os stuff. In the end, I setup the pi for airplay, and that works for my family.
If it for my, I would setup for PCP. I have a pi running as a LMS server so I can run pcp whenever I want to.
BTW, there are other choices like volumio and moode
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 3rd October 2018, 02:32 AM   #6
Can PCP be dualbooted with Raspbian? Can't seem to find anything on that...
Old 3rd October 2018, 10:28 AM   #7
wealas is offline wealas
No need to, just use another SD card
Old 4th October 2018, 12:21 AM   #8
Right, but that seems inefficient if I just want to turn it on...is it doable? I'm probably going to start my build in the next week or so.
Old 4th October 2018, 02:48 AM   #9
I haven't heard of running a grub-like linux bootloader to select between different OSes on a Raspberry Pi, but it's all open source software, so anything is possible.
Certainly switching SD cards is the most common way to boot alternate OSes on an RPi.
-Neil N0FN
Old 5th October 2018, 07:11 PM   #10
You can dual/multi boot anything on a pi
multi boot
I do need to admit that I gave up on multi boot and not sure how accurate that page is.
The basic stuff is fine, and I remember getting far enough to prove that it would work in my mind, but got sidetracked and stopped working on it.
It was easier to use multiple sd cards, and just swap them out.
My system is here
Help me figure out a Raspberry Pi interfaceHide this!Advertise here!
Raspberry pi best sound with USB interface or digi pro + kimschips Digital Source 3 24th April 2018 02:59 PM
[FreeDSP] Raspberry Pi interface camelator Digital Line Level 4 18th September 2016 10:54 AM
Audio interface, Control interface, Codecs and MCUs arjunm009 Digital Line Level 1 14th May 2015 12:35 PM
Little USB/Digital interface box with I2S interface QA01 lxiaob Digital Source 0 2nd January 2013 04:51 AM
Help me figure something out....Please sturmj Solid State 1 12th January 2012 08:16 AM
