PC Based Computer music servers, crossovers, and equalization
SRC hat for Raspberry Pi
Old 30th August 2018, 08:41 PM   #1
DRONE7 is offline DRONE7  New Zealand
Default SRC hat for Raspberry Pi
Interesting addition.. a hat that does src and up-sampling to dsd options.
Raspi-4137 Raspberry Pi Digital Network Player Supports 32bit 384K DSD256 | eBay
There have been discussions in this thread as to the advantages of feeding ESS90xx dacs with dsd data.
ES9038Q2M Board
This board does on the fly conversion so no need to store huge files and i2s output so no usb to i2s needed.
Uses hifiberry driver.. I'm guessing sda/scl gpio used so may curtail other i2c devices such as displays ?
Alternative stand alone version...
AK4137 I2S/DSD Sample Rate Conversion Board Supports PCM/DSD Interconversion DOP | eBay
Old 26th March 2019, 02:59 PM   #2
dezo is offline dezo
Hi,is this board something similar to Allo Kali?Does it improve I2S signal from RPi?
I would like to use it as a source for my Mamboberry DAC.Is it possible?
Thanks.
Old 26th March 2019, 06:46 PM   #3
This board is a Sample Rate Converter...it re-samples (up-samples) to your chosen sample rate.
The benefits seem to be most noticeable when the output ie resampled is DSD 256... if your DAC does not accept this then it will be of little use.
The Kali is a reclocker. It fixes the RPi's clocking inadequacy.
I have both and prefer the Kali for sound quality... It also currently has an incompatibility with the Linux kernel requiring a workaround for 24 bit sample rates.
It seems this may be fixed for newer kernels.
It does not work with DSD files.
Depending on your playback format needs this may affect your choice.
SRC hat for Raspberry PiHide this!Advertise here!
DAC for Raspberry Pi LaxAnErde Digital Line Level 40 15th May 2019 03:00 AM
Raspberry Pi DAC Help! pamantea Digital Source 31 19th April 2019 10:24 PM
I2s DAC + XLR for Raspberry pi? JonesySA PC Based 6 6th May 2018 11:01 PM
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
