PC Based Computer music servers, crossovers, and equalization
Best crossover solution for 2.1 from PC with tpa3255?
Old 14th August 2018, 04:31 AM   #11
jplesset is offline jplesset  United States
You can use a 5.1 or 7.1 sound "card", and connect your sub to the ".1" output... You do not really need to use the crossover in the sub.
Old 14th August 2018, 01:08 PM   #12
earsofgold is offline earsofgold
I just spent 300 bucks on a pro soundcard for music production, I can't use some crappy high-latency 5.1 card.
Not trying to be difficult, I just can't believe Shenzen isn't all over this with $10 crossover boards!
Thanks for the replies all, I'm looking into minidsp or freedsp. Seems like a lot of effort when lots of cheap amps have 2.1, but all the home subs are self-powered, I haven't seen passive home ones, only car enclosures. Hmm. Anyway I'm sure a minidsp will come in handy later anyway.
Old 14th August 2018, 02:00 PM   #13
jiiteepee is offline jiiteepee  Finland
Hmm... by 6i6 specs, there are four outputs (+ headphone output) to use ... why not just use one of those output ports for sub ... .
As I mentioned already both software which I mentioned handles I/O as mono channels --> by using three mono outputs from 6i6 (two for bookshelf speakers, one for powered sub) with mentioned software you be able to make needed routings and filtering for L/R channels and SUB channel. If there are delay diffrence between the sub and speakers, it can be fixed through mentioned software as well.
Old 14th August 2018, 06:53 PM   #14
phofman is online now phofman  Czech Republic
PCI(e) soundcards (incl. Intel HDA) can usually reach very decent latencies. Of course it requires good drivers and good OS.
If needed, it is trivial to disconnect the internal amp and use the SW and passive. Often the internal electronics is not worth a dime anyways.
Old 15th August 2018, 01:54 AM   #15
Another reason I don't want another soundcard is that Ableton only supports a single soundcard at once.
Good idea, now I'm considering saving time and money and just getting a 2.1 TPA3255 board and doing that. Still not convinced by the quality of the one premade board available that includes a crossover though. There's no way to adjust the crossover frequency, just treble/bass controls.
Seems slightly silly to pay for a powered sub when you're only using it as a passive though. Plus voiding the warranty - I'd need to find a way to get the speaker connectors to exit the enclosure which might mean drilling a hole.
I wonder what the difference in quality of the actual sub driver/enclosure actually is between powered subs, or if you're just paying for a more powerful plate amp.
Old 15th August 2018, 08:03 AM   #16
DRONE7 is offline DRONE7  New Zealand
At a yard sale bought one of these.....
Silver W-12 | Subwoofer | Monitor Audio
Plate amp is just a joke.....!(almost every cap is bulged..) .....although the cabinet and driver are in great condition.
Removed the plate amp (500 watt RMS you've got to be kidding !!) and powered from 2.1 Allo DAC with dedicated
Plinius power amp.... when you've current to spare...
(.....sub cost....cough...$5.00....cough US....)....
Piano 2.1 DAC
Plinius - SB 301 -
Old 15th August 2018, 10:23 AM   #17
If you go this way with EqualizerAPO then you could use filters something like this to cut the low freq for bookshelf speakers and cut the high freq for sub :
Code:
Copy: C = 0.5 * L + 0.5 * R
# if needed
#Copy: Sub = 0.5 * L + 0.5 * R
# Preamp: -command if needed
# 6i6 outputs 1, 2
Channel: L R
# Delay: -command if needed
# 48dB/oct HighPass filter w/ cut-off at <n> Hz
Eval: cutoff = 80
Eval: Q1=1/(2*sin((pi/8)*(0+1/2)))
Filter 1: ON HPQ Fc `cutoff` Hz Q `Q1`
Eval: Q2=1/(2*sin((pi/8)*(1+1/2)))
Filter 1: ON HPQ Fc `cutoff` Hz Q `Q2`
Eval: Q3=1/(2*sin((pi/8)*(2+1/2)))
Filter 1: ON HPQ Fc `cutoff` Hz Q `Q3`
Eval: Q4=1/(2*sin((pi/8)*(3+1/2)))
Filter 1: ON HPQ Fc `cutoff` Hz Q `Q4`
# 96dB/oct (just double the above)
#Eval: Q1=1/(2*sin((pi/8)*(0+1/2)))
#Filter 1: ON HPQ Fc `cutoff` Hz Q `Q1`
#Eval: Q2=1/(2*sin((pi/8)*(1+1/2)))
#Filter 1: ON HPQ Fc `cutoff` Hz Q `Q2`
#Eval: Q3=1/(2*sin((pi/8)*(2+1/2)))
#Filter 1: ON HPQ Fc `cutoff` Hz Q `Q3`
#Eval: Q4=1/(2*sin((pi/8)*(3+1/2)))
#Filter 1: ON HPQ Fc `cutoff` Hz Q `Q4`
# 6i6 outputs 3, 4
Channel: C Sub
# 48dB/oct LowPass filter w/ cut-off at <n> Hz
Eval: cutoff = 250
Filter 2: ON LPQ Fc `cutoff` Hz Q `Q1`
Filter 2: ON LPQ Fc `cutoff` Hz Q `Q2`
Filter 2: ON LPQ Fc `cutoff` Hz Q `Q3`
Filter 2: ON LPQ Fc `cutoff` Hz Q `Q4`
#Filter 2: ON LPQ Fc `cutoff` Hz Q `Q1`
#Filter 2: ON LPQ Fc `cutoff` Hz Q `Q2`
#Filter 2: ON LPQ Fc `cutoff` Hz Q `Q3`
#Filter 2: ON LPQ Fc `cutoff` Hz Q `Q4`
... or use GraphicEQ from EqualizerAPO.
If you want to use ASIO/KS level output instead of Windows default (WASAPI Shared) then use the Equalizer APO Voicemeeter integration option (set Voicemeeter to use ASIO/KS).
Old 15th August 2018, 09:28 PM   #18
Why would you want to use more than one multichannel soundcard?
Old 13th September 2018, 02:19 AM   #19
Wow, $5 for that?!
Probably an angry spouse getting rid of her poor partner's stuff!
Thanks a lot for the detailed info.
Yeah I understand why you would ask that question.
TBH I think that EqualizerAPO setup is not going to work for me.
I have a mistrust of the latency that must be created by running everything through EqualizerAPO and the extra complexity. My whole system is a complicated and fragile ecosystem and I'm skeptical of running Ableton with EqualizerAPO. Ableton is quite sensitive to soundcard and I guess EqualizerAPO creates a virtual soundcard to run everything through? I specifically bought that soundcard from checking the latency numbers and it is one of the best. I'm playing VST instruments live so latency is very important.
I usually run my O2 headphone amp from outputs 1-2 and my monitor speakers from 3-4.
The physical monitor volume control on the 6i6 only affects outputs 3-4, and the new TPA3255 amp that I'm setting up has no volume control so I will need to use that physical control to control the output from the monitor speakers/sub. I need the headphones to run fullrange so I need separate outputs for that or else I'll need to manually adjust the volume of the sub all the time which is not very accurate or convenient.
Not sure I explained that all that well but that's what I'm thinking.
Best crossover solution for 2.1 from PC with tpa3255?Hide this!Advertise here!
What is wrong with TPA3255? diytoon Class D 603 Today 07:29 AM
tpa3255 with 16 ohm load robinlawrie Class D 46 12th September 2017 05:04 PM
TPA3255 or TDA7498E drauzinho Class D 10 4th September 2017 03:47 PM
Looking for a solution for EQ, control and active crossover. Wiggle8 PC Based 15 20th April 2017 03:07 AM
Active crossover + EQ solution? Kev06 Analog Line Level 6 29th November 2015 10:04 AM
