PC Based Computer music servers, crossovers, and equalization
Raspberry Pi with Piano2.1 DAC DSP and Volumio2
Old 7th December 2018, 01:51 PM   #101
DonVK is offline DonVK  Canada
DonVK's Avatar
^ That's unfortunate. I'll have to check that on volumio when I do some measurements on the standard firmware.
In the meantime you can try the firmware from post #91. It uses a less aggressive BW2 instead of LR4 for DAC#0. If your fronts have a sealed woofer it will match slopes much better to the subwoofer.
Tonight, I'll post a firmware pkg that is pass through for DAC#0 (no HP filter).
Old 7th December 2018, 06:36 PM   #102
DonVK's Avatar
Default Firmware - DAC0 Front (L&R) pass thru, DAC1 sub LP LRx
@komerdoor - this is for your evaluation. You can always mix & match with other firmware in this thread.
Old 8th December 2018, 02:38 AM   #103
komerdoor is offline komerdoor  Netherlands
Thank you very much, I will try it out later.
Old 8th December 2018, 09:19 AM   #104
Ok tried it. I do not get any sound. Both firmware binaries loaded fine, so I am not sure if this is because I use the Allo Volt. I replaced the 2.2 firmware and switched to 2.2 mode. It works again after I restore the original firmware.
Old 8th December 2018, 04:59 PM   #105
DonVK's Avatar
^ I just downloaded and tried 2.2-5 and it works fine via Volumio. It's unlikely that the amplifier shield is causing the problem. It's more likely a problem with the copy, or permissions, or "sticky" configurations.
I've put screenshots of the directory permissions and contents of the 2.2 directory after I copied the 2.2-5 firmware into it. Note the file sizes which are related to the firmware build.
With Volumio, 1) I copy the firmware files over to the 2.2 directory, 2) select the mode I want, 3) reboot the system. I can see from dmesg that the old configuration (sticky) is initially loaded then it's overwritten with the new configuration.
Old 9th December 2018, 02:34 AM   #106
Thank you. It works, but only if I set my MPD settings to the following:
audio_output_format "192000:32:2"
Instead of:
audio_output_format "384000:32:2"
Kernel log of firmware being loaded when I play a song using the 384000 setting in MPD:
Code:
[  134.775288] pcm512x 1-004c: Dsp Firmware File Name: allo/piano/2.2/allo-piano-dsp-192000-60-0.bin
[  134.987251] pcm512x 1-004d: Dsp Firmware File Name: allo/piano/2.2/allo-piano-dsp-192000-60-1.bin
Old 9th December 2018, 02:48 AM   #107
DonVK's Avatar
That makes sense. If you look at the DSP bin files the highest rate supported is 192K. Good to see you have a solution.
Old 9th December 2018, 03:03 AM   #108
Ah I never knew to be honest, but I just read the specs . Sorry for bothering you with all this and thanks again for the firmware binaries. Will play with it some more tomorrow.
Raspberry Pi with Piano2.1 DAC DSP and Volumio2Hide this!Advertise here!
DAC for Raspberry Pi LaxAnErde Digital Line Level 24 26th April 2018 06:58 AM
Tutorial: Raspberry Pi as Music Server, DSP, and Crossover jrubins PC Based 75 6th January 2017 05:28 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Which DAC for Raspberry Pi? Miller-8 PC Based 14 10th August 2016 04:18 AM
Raspberry Pi DAC Help! pamantea Digital Source 26 8th November 2015 08:50 PM
