PC Based Computer music servers, crossovers, and equalization
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry Pi
Old 11th September 2019, 06:59 PM   #881
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry Pi
If you put multiple supercaps per rail it's likely youd hit the current limit on the regs at turn on. Ime one per rail, 1-1.5f does the job.
Old 12th September 2019, 10:31 AM   #882
soundcheck is offline soundcheck  Germany
BTW.
Congratulations Ian.
You're now a real commercial guy. Audiophonics is selling your products now.
That's gonna be more convenient then these group-buys, especially for me (us?) over here in Europe.
PS: I figured that out while figuring out where to source the DAC.
Old 15th September 2019, 04:12 PM   #883
jimk04 is offline jimk04  United Kingdom
Just bought a dual mono dac with IV std and isolator. I see it is possible to have an spdif input. How does one add an optical into the dac? I see the 3 through holes but could do with a bit mire guidance. Thanks
Old 15th September 2019, 06:04 PM   #884
wealas is offline wealas
If you want optical input you'll need something like this: TOSLINK Optical Input to Coaxial S/PDIF Module | eBay
Old 16th September 2019, 04:15 PM   #885
TioFrancotirador is offline TioFrancotirador  Poland
Not exactelly. The one you proposed has onboard regulator from 6-20DC down to 3.3V.
If you want to connect directely to Ian's DAC HAT then get something like this:
192K Optical SPDIF receiver - DIYINHK
It is also much cheaper
Old 18th September 2019, 09:04 AM   #886
Thanks for those replies. I've ordered the dIYINHK board. I'll see how I get on when it all arrives but look straight forward enough.
@TioFranco
Interested to read earlier in the thread that you feed a Google Chromecast audio into Ian's ESS dac . You obviously find the SQ from the CCA at a hi enough level to pair with Ian's Dac stack. I have one and if I can use it to stream spotify into my main system then great. What do you use to power your CCa?
Old 18th September 2019, 09:12 AM   #887
@TioFranco
CCA? What do you mean ...
Old 18th September 2019, 09:13 AM   #888
Sorry....Chrome Cast Audio
Old 18th September 2019, 09:22 AM   #889
@TioFranco
Power for CCA is not important since it is connected via toslink (galvanically isolated) to Ian's board. Just use stock SMPS.
Now you have two options to connect it:
1. asynchronous - just connect CCA to the toslink receiver from diyinhk connected to Ians dual es9038q2m board.
2. full synchronous (PLL turned off) - connect your CCA to some cheap ak4137 receiver from ebay, then connect I2S to FifoPi reclocker - that is best you can get.
As output stage use transformer from bisesik - find in separate thread.
Old 18th September 2019, 10:00 AM   #890
Thanks. No Fifo yet so will be ASR for now.
Link to bisesik thread?
Thankyou
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry PiHide this!Advertise here!
I/V stage for ES9028Q2M gandolf Digital Line Level 25 9th February 2018 06:04 AM
ES9028Q2M balanced output evert1 Digital Line Level 0 26th December 2017 01:30 PM
ES9018K2M: best (Raspberry)-OS/384 khz + dtoverlay sfb2 PC Based 2 30th May 2017 09:43 PM
Hats off to Mr Pass, encouragement to new members Russellc Pass Labs 10 17th May 2015 08:23 AM
Hats make better bass? xstephanx Subwoofers 11 9th February 2005 10:59 AM
Copyright ©1999-2019 diyAudio
