PC Based Computer music servers, crossovers, and equalization
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry Pi
Old 24th February 2019, 11:31 PM   #741
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by Deenoo View Post
@Ian
I have read and I found only these: To enable S/PDIF receiving, PIN1 of jumper switch S2 needs to be switched to “ON”.
That's all or could you add something else?
THX! Dee
That's all.
Good weekend.
Ian
Old 4th March 2019, 01:12 AM   #742
ofswitched is offline ofswitched  Taiwan
In theory, in a single ESS chip inside, the two channels may also cause jitter in a different time, resulting in poor listening. In contrast, if two ESS chips are used, jitter in the different time will only be more serious, making the sound more confusing, so that Dual Mono is not a good design. Many brands of DACs do not use Dual Mono, of course not because ESS chip is too expensive to afford. The data is not necessarily beautiful, I hope the next version can only use a single ESS chip, but it is better to listen.
Old 4th March 2019, 01:35 AM   #743
iancanada's Avatar
@ofswitched
I understood what you are concern about. But I think it really doesn't make sense.
DAC in mono block configuration improves the over all performance but doesn't introduce additive jitter as long as using same MCLK source.
I designed the single ES9038Q2M DAC as the first generation. But found some issue by comparing with my other DAC HAT. That's why I re-designed this ES9038Q2M dual mono DAC HAT as the second generation. If you ask me which is better, I can tell you that I'm really happy with the new dual mono one.
A lot of high-end DACs use dual mono configuration. They based on the same principle. if you want to know more about the principle, you can search my previous posts.
Ian
Old 7th March 2019, 07:22 AM   #744
Originally Posted by iancanada View Post
@ofswitched
Ian
Thank you for your reply, but I can't find your previous posts, so you can explain further it doesn't introduce additive jitter as long as using same MCLK source?
Old 13th March 2019, 08:35 AM   #745
copper31 is offline copper31
Ian, would you please share with us the SQ difference between Dual Mono ES9038Q2M and ES9028Q2M ? Thanks!
Old 16th March 2019, 06:16 PM   #746
paoloilpizzo is offline paoloilpizzo  Italy
Hi Ian,
I'm very interested in using your Transformer I/V PCB mini KIT with LL1544A Transformers.
My doubt is: do I have to pay attention to the input impedence of my Amplifier ?
I understand that using these trasformers the output impedence is higher the the "standard" OPA board.
May I have an impedence problem ?
Which is the output impedence using your Dual Mono ES9038Q2M DAC HAT with the transformer KIT with LL1544A Transformers ?
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry PiHide this!Advertise here!
I/V stage for ES9028Q2M gandolf Digital Line Level 25 9th February 2018 06:04 AM
ES9028Q2M balanced output evert1 Digital Line Level 0 26th December 2017 01:30 PM
ES9018K2M: best (Raspberry)-OS/384 khz + dtoverlay sfb2 PC Based 2 30th May 2017 09:43 PM
Hats off to Mr Pass, encouragement to new members Russellc Pass Labs 10 17th May 2015 08:23 AM
Hats make better bass? xstephanx Subwoofers 11 9th February 2005 10:59 AM
Copyright ©1999-2019 diyAudio
