PC Based Computer music servers, crossovers, and equalization
sensorless DSP cone excursion limiter
Old 24th February 2017, 07:32 PM   #61
CharlieLaub is offline CharlieLaub  United States
Originally Posted by bcodemz View Post
Can this be adapted to implement equal loudness curves?
It's a related issue but no, it can't do that.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 18th June 2018, 01:28 PM   #62
wernie is offline wernie
Replying to myself 1,5 years later .. :-) I just finished the project and what I did so far on this topic/area is adding a low shelf (boost) to compensate for the 6 dB/octave roll-off of the OB woofer below 200 Hz and at the same time add an 8th order high pass filter with cutoff 20 Hz since my woofer's freq response below 40 Hz drops steeply anyway and i thought the high pass might be good to add some protection against high energy in the low area below 40 Hz.
Old 25th June 2018, 04:43 PM   #63
I'm glad you were inspired to implement these filters... however, I don't see how that is related to the original topic - excursion limiting. That's only supposed to kick in when the cone is exceeding some predetermined threshold (e.g. Xmax, or some distortion threshold, etc.). Otherwise the "limiting" action is out of circuit.
You have simply implemented some filters that are active all the time. Please correct me if I am wrong, but from what you wrote I believe that is your approach. It's just continuous-time filtering. It's will not limit excursion as power or input level is increased.
Old 7th July 2018, 11:29 AM   #64
Correct, I just wanted to give an update on my project. It’s indeed not a limiter. In practice though my thought is that a 20 Hz highpass doesnt hurt and I dont know if this ever occurs but if some <20Hz (or dc) high amplitude signal is sent it wont reach my woofers. And >40 hz I expect I wont reach over excursion as long as I get to know my woofers a bit and learn what music levels are safe and dont use weird music or test signals with extreme and unnatural bass amplitudes. But still: Im not denying that a real (nonlinear) excursion limiter would be a great feature.
sensorless DSP cone excursion limiterHide this!Advertise here!
Frequency dependent limiter to avoid one excursion above x max hahfran Multi-Way 9 12th April 2016 06:31 PM
Cone Excursion johnc124 Subwoofers 7 10th April 2009 03:45 AM
Question about cone excursion. perpetual Subwoofers 15 5th May 2005 02:45 PM
calculating cone excursion? Jim85IROC Multi-Way 11 3rd April 2004 09:41 AM
Peak cone excursion Vikash Multi-Way 8 9th July 2003 07:21 PM
Copyright ©1999-2019 diyAudio
