PC Based Computer music servers, crossovers, and equalization
PC As Active Crossover
Old 21st June 2016, 04:00 PM   #11
tomchr is offline tomchr  Canada
tomchr's Avatar
Reaper with the ReaEQ plugin works well: www.reaper.fm
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 21st June 2016, 04:25 PM   #12
vladimirb0b is offline vladimirb0b  United States
Can you recommend a particular sound card/multichannel dac?
Old 21st June 2016, 04:29 PM   #13
jplesset is offline jplesset  United States
Hm. I admit that I got a cheap one off Amazon for $25. It's a simple USB 7.1 box. Sounds just fine to me. When I've looked at blind testing, most folks can't tell one from another, so I don't bother playing in the expensive electronics leagues. I can hear speaker differences, but never have been able to hear amps, sound cards, etc.
Old 21st June 2016, 04:38 PM   #14
samsagaz is offline samsagaz  Argentina
Oh i will trip to USA this week and will purchase two Raspberry
Old 21st June 2016, 04:43 PM   #15
jiiteepee is offline jiiteepee  Finland
If you mean for crossover use, integrated chip is good enough. It's common those have 8 output channels (maybe even separate DAC chip for each stereo pair (i.e. 4 DACs)). which allows build a 4-way crossover
Old 21st June 2016, 05:26 PM   #16
tomchr's Avatar
I'd recommend any of Focusrite's products. I've used the Saffire PRO24. Works great. It uses the better DACs from Cirrus (-106 dB THD as I recall) and the flagship Cirrus DAC CS4398 if I recall correctly for the headphone out.
I'm tempted to get one of the Scarlett series as they take USB input. The Saffire is FireWire.
Tom
Old 21st June 2016, 05:36 PM   #17
Tom
I see some goods reviews about Scarlett!
Offtopic:... Your sign/footer are nice, didnt know abt Modulus-86 Looks like will try to order some kit asap to test it
Old 22nd June 2016, 06:48 AM   #18
zarandok is offline zarandok  Austria
zarandok's Avatar
Originally Posted by jiiteepee View Post
It would be just JRiver this and JRiver that then.
I do not understand your message...!?
I am fully statisfied with the sound quality of this program. Only the user interface should be better and some practical functions a little improved...
Old 22nd June 2016, 07:52 AM   #19
IMO, system wide crossover system is the way to go. DSP features in JRiver are for JRiver only so using JRiver for crossover ties to use JRiver only (i.e JRiver this JRiver that).
Old 22nd June 2016, 08:36 AM   #20
zarandok's Avatar
Yes, you are right!
This is why I am using both, JRiver und EqAPO.
The first for listening quality music (ASIO), the last for common use e.g. system sounds, youtube, games so on (DirectSound)...
PC As Active CrossoverHide this!Advertise here!
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
Active Crossover using PC and multi ch. Soundcard? vision Digital Source 22 7th July 2012 11:59 PM
active crossover from a pc soundcard? bser Digital Source 17 18th August 2005 03:19 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
