PC Based Computer music servers, crossovers, and equalization
Something cool for Raspberry Pi/ODROID: I2S/DSD isolator HAT with native DSD decoder
Old 21st September 2018, 01:18 AM   #361
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by miklau View Post
Hi Ian
I managed to get hold of a IsolatorPI from a fellow DIYaudio member. The board is very nice and have already installed it with great succes.
I have been messing a bit with the master/slave jumbers on the IsolatorPi. I can only get it to work in slave mode. I have connected the I2S signal to a SRC4192 ASRC module from Twisted Pear(Metronome). The board is set to output master mode at 256fs. That signal is passed on to a PCM1794a COD DAC also from Twisted Pear.
Maybe i have misunderstood the Master/slave idea but do you know why the master jumper setting is not working?
Thanks in advance
Btw: Your new FifoPi looks really good! That could be the newt upgrade
Thank miklau,
The IsolatorPi master mode was designed to work with master mode RPi DAC HAT such as Hifiberry Pro +. Those master mode DAC HATs usually need Linux driver to run.
For external high-end DAC, to improve sound quality, you will need FifoPi to make audio master clock local and asynchronized with clocks from RPi.
Ian
Old 24th September 2018, 01:25 PM   #362
miklau is offline miklau  Denmark
@jonners @iancanada
Thank you both for the help and fast reply I will keep an eye out for the FifoPI
I have also tried a KALI Reclocker in master, but would this be same regarding the Linux Driver?
I am trying to make a mute function and the PCM1794s soft mute requires a pin set to high.
I would like to use the isolated GPIO pin for this since I have a shared ground between the DAC power supply and the Isolator Pi. The ground to the RPI is not shared.
I have tried to use Pin 15,22,31 but they seem to be always pulled high? Can I control these pins or would you recommend a relay/transistor and then use the unisolated side?
Regards Mikkel
Old 24th September 2018, 02:50 PM   #363
iancanada's Avatar
@jonners @iancanada
@miklau
FifoPi has built-in isolator and an isolated mute signal output(active high). I think it works for your application.
FifoPi also doesn't need any special Linux driver. It works with any external DAC including PCM1794 with providing local MCLK.
Ian
Old 24th September 2018, 03:54 PM   #364
Hi Ian
Thanks again Sorry if I ask wrong but would I be possible to control the Isolated pins 15,22,31 on the IsolatorPi? I just took this from page 4 at the IsolatorPi User manual where they are listed as pull up with the 4.7k resistor. But not sure if they are controllable or always high?
Regards Mikkel
Old 24th September 2018, 09:30 PM   #365
iancanada's Avatar
@miklau,
That's no any problem. You can use GPIO pin31 on my IsolatorPiII as the mute signal. It's 100% isolated from RPi ground.
Ian
Old 25th September 2018, 09:38 AM   #366
@Ian
Thanks again Is this only for the IsolatorPi II? I have tried to measure this on the IsolatorPi I and that pin seems to be high at 3.3v all the time...
Regards Mikkel
Old 26th September 2018, 12:08 AM   #367
iancanada's Avatar
@miklau
Yes, it's possible. IsolatorPi I has a reserved GPIO pin15 for isolation function. But it was not standard equipped. You need to assemble a SMT optical isolator by your self. Please let me know if your really want to do so. However IsolatorP II can be used directly for this feature.
Ian
Old 18th October 2018, 11:19 AM   #368
Default Power sequence of Isolator Pi and RPI
Hi Ian
I was just wondering if everthing is fine if I power the isolator pi and my raspberry pi simultaneously? Your manual just state to power the Isolator first and then the RPI. If there is sound is everything fine or would SQ improve if powering the RPI with a 1-2 sec delay?
Old 8th November 2018, 03:05 PM   #369
Greg121986 is offline Greg121986
I am trying to understand whether I should wire my ODroid C2 directly to my DAC by I2S, or if there would be a major benefit by going to something like the isolator hat, FIFO board, McFifo? There are quite a few choices here so it's difficult to determine which is the best one. I do not wish to use RPI because of its slow Ethernet connection. I want to keep the ODroid C2 because of its GbE and eMMC storage. I must find the best choice for ODroid C2.
I was planning on making a cable to run from my C2 7 pin I2S header to the RJ45 input of my Audio-GD NFB7.77 according to the photo attached. The NFB7.77 should be able to clock the signal without the MCLK present. Without the MCLK, do I need to worry at all about poor clock quality from the C2? Would there be a vast improvement by going with a McFifo or I2S isolator hat? All input is appreciated.
Something cool for Raspberry Pi/ODROID: I2S/DSD isolator HAT with native DSD decoderHide this!Advertise here!
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 120 14th November 2017 08:25 AM
Raspberry Pi: I2S Fundamental issues! diyinhh Digital Line Level 24 5th January 2016 12:59 AM
Raspberry Pi I2S question LinuxGeek PC Based 1 6th October 2015 10:21 PM
Raspberry Pi I2S output as Asynchronous USB-to-I2S Tinco Digital Line Level 26 27th September 2013 03:18 AM
How to connect PMD-100 chip with Sony's CDX 2750Q Dsd decoder soundofvoid Digital Source 1 12th April 2007 10:15 PM
