PC Based Computer music servers, crossovers, and equalization
PeppyMeter
PeppyMeter
Thread Tools
Old 18th October 2021, 04:16 PM   #501
t0bit0bsen is offline t0bit0bsen  Germany
Hi Francesco,
try to replace in line 129
Code:
unsigned int bins[spectrum_size+1];
by
Code:
unsigned int bins[] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 22, 26, 31, 36, 43, 51, 61, 72, 86, 102, 121, 144, 170, 202, 240};
and remove all the "create bins" stuff from line 160 to 181
and compile it again.
Note: This is untested. No guarantee.
Note2: The Spectrum Size you wished is 32.
Kind regards
Tobias
Old 19th October 2021, 10:24 PM   #502
fdealexa is offline fdealexa  Italy
Thank you very much, Tobia.
I have tried and it is much better than the previous one.
I have 2 questions:
1. How can you calculate the numbers you suggested? So if you change something, I don't need to bother you.
2. How can I exclude any window options? It seems to me that 2 of the 3 options create a lot of noise on all frequencies.
Thanks again and greetings,
Francesco
Old 20th October 2021, 06:19 AM   #503
Sorry, Tobias.
The first question is:
How can you calculate the numbers you suggested? So if I would like to change something, I don't need to bother you.
Thanks again and best regards,
Francesco
Old 21st October 2021, 12:19 PM   #504
the result of the fftw-algorithm are 256 frequency bins (+1 DC). They are equal distributed. The maximum frequency is sample_rate/2, eg. 22.05kHz for 44.1kHz sample rate.
So the first frequency is
22050Hz / 256 ~= 86 Hz
The second is 2x the first:
2x 22050Hz / 256 = 172Hz
and so on.
The numbers represent the indices used for calculation. E.g.:
bins = {1, 2, 3, 5, 9}
returns values for frequencies:
Code:
for(x = bins[m]; x < bins[m+1]; x++)
m=0:
x = 1 .. x < 2
amplitudes summed for
f=f(1) = 86Hz
m=1:
x = 2 .. x < 3
f = f(2) = 172Hz
m=2:
x = 3 .. x < 5
f = f(3) = 258Hz and f = f(4) = 345Hz
m=3:
x = 5 .. x < 9
f = f(5) = 431Hz up to f = f(8) = 689Hz
I hope I could clarify more than I caused confusion...
Kind regards,
Tobias
Old 21st October 2021, 09:25 PM   #505
Thanks Tobias,
I will try and inform you about it.
Francesco
Old Yesterday, 10:48 AM   #506
Hi Tobias, hi everyone,
after numerous and thorough tests I am pretty sure I can say that my opinion is that:
1. The frequency spectrum sent by peppyalsa ends at 44100 and not 22050 (such as try using "logarithmic_frequency 0" and only half of the values sent will be different from 0).
2. The "Window function for FFT" cannot be avoided (such as try using "window 0" and try to listen to a fixed frequency signal such as a 1000Hz sine wave and you can notice many of the values sent will be other than 0).
I would be very happy if you could give me your point of view on the items just described.
Forgive me if I am too pushy and pressing.
Thanks for everything and have a nice weekend,
Francesco
Old Today, 10:06 AM   #507
Hi Francesco,
thanks for sharing your opinion.
1.
The FFT always ends at the half of your sample rate. If the sample rate is 44100Hz, the upper most frequency is 22050Hz. For confirmation you can check it on e.g. on a PeppyPlayer, see attachment. What is your sample rate?
2. You can disable the windowing be setting it to any other number than 1, 2 or 3, as the windowing is only applied if it is set to one of these numbers:
Code:
		if (window_function == 1) {input_buffer[buffer_index] = input_buffer[buffer_index] * hann[buffer_index];}
		if (window_function == 2) {input_buffer[buffer_index] = input_buffer[buffer_index] * hamm[buffer_index];}
		if (window_function == 3) {input_buffer[buffer_index] = input_buffer[buffer_index] * black[buffer_index];}
Maybe your input signal is not a pure sine wave. Clipping can cause additional frequency responses. Have you tried a not so "loud" version of your test sample?
Kind regards
Tobias
Old Today, 10:37 PM   #508
rpi is offline rpi  United States
Francesco, can you share the testing file which you use and the output (screenshot) which you observe? That would help to reproduce the issue (if any).
Thanks in advance!
  Reply to this post
PeppyMeterHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
