PC Based Computer music servers, crossovers, and equalization
PeppyMeter
PeppyMeter
Thread Tools
Old 15th October 2021, 02:23 PM   #491
t0bit0bsen is offline t0bit0bsen  Germany
Hi fdealexa,
for every spectrum 512 time-domain-samples are taken. The fftw-algorithm calculates an output of 512/2+1 values, while the first one is the DC-part of the signal.
If you select a linear frequency axes of 30 values, the frequencies are
f(n) = n * (sample_rate/2) / 30
resulting in x kHz:
Code:
0.735000000000000	1.47000000000000	2.20500000000000	2.94000000000000	3.67500000000000	4.41000000000000	5.14500000000000	5.88000000000000	6.61500000000000	7.35000000000000	8.08500000000000	8.82000000000000	9.55500000000000	10.2900000000000	11.0250000000000	11.7600000000000	12.4950000000000	13.2300000000000	13.9650000000000	14.7000000000000	15.4350000000000	16.1700000000000	16.9050000000000	17.6400000000000	18.3750000000000	19.1100000000000	19.8450000000000	20.5800000000000	21.3150000000000	22.0500000000000
for an input if 41.1kHz. For log-spaced frequencies it is more complicated, as for the lower frequencies the resolution of the fft is not high enough to use log spacing in the lower frequency band.
the log-spaced frequencies are [kHz]:
Code:
0.0861328125000000	0.172265625000000	0.258398437500000	0.344531250000000	0.430664062500000	0.516796875000000	0.602929687500000	0.689062500000000	0.775195312500000	0.861328125000000	0.947460937500000	1.03359375000000	1.11972656250000	1.20585937500000	1.37812500000000	1.63652343750000	1.98105468750000	2.41171875000000	2.92851562500000	3.44531250000000	4.22050781250000	4.99570312500000	6.02929687500000	7.23515625000000	8.78554687500000	10.5082031250000	12.6615234375000	15.2455078125000	18.3462890625000	22.0500000000000
You can find a graphical representation in the attachment.
Unfortunately there is no physical correct way to combine the frequency bins, so the fft output is summed up over the values inside of a bin. This can cause a bit of overlapping.
The output is unsigned int, mono.
I got really good results using PeppyPlayer and the screensaver in it. I tested it using a frequency-generator-app on my mobile connected via bluetooth. You can see the result of a frequency sweep for spectrum_size = 32 in the attached movie.
If the amplitude of the signal is to high, there is distortion resulting in additional frequencies.
If you use spectrum_size = 256 you will get fine needles for pure sine input.
Kind regards
Tobias
Old 15th October 2021, 03:27 PM   #492
fdealexa is offline fdealexa  Italy
Thanks, Tobias, hi all
I will try with 256 and inform you.
in attachement (Photo Test.zip) you can find the compared (CAVA vs PEPPY) results of some sine wave.
Furthermore you can see, in attached too (Video Test.zip), the compared results of the same short music.
All of them have been created with the following parameters:
type peppyalsa
decay_ms 400
meter "/var/tmp/peppyfifo"
meter_max 100
meter_show 0
spectrum "/var/tmp/peppyfifosa"
spectrum_max 100
spectrum_size 30
logarithmic_frequency 0
logarithmic_amplitude 1
smoothing_factor 20
window 1
Best regards and thanks to all of you,
Francesco
Photo Test.zip
Video Test.zip
Old 15th October 2021, 04:36 PM   #493
I forgot to mention that there might be still a bug in the Spectrum part of Peppyalsa. Did you compile it by yourself? You can try this:
in spectrum.c, lines 190 and 191:
pow( output_buffer[m][ 0 ], 2 ) +
pow( output_buffer[m][ 1 ], 2 ) );
you have to change the index m to x:
pow( output_buffer[x][ 0 ], 2 ) +
pow( output_buffer[x][ 1 ], 2 ) );
In the next release it will be certainly fixed.
Best regards
Tobias
Old 15th October 2021, 05:53 PM   #494
Hi Tobias,
the line you mentioned to be modified is at 189 but, unfortunatly, I don't know how to compile it: is it enough "gcc -o"? Could you please be so kind to help me on this matter too?
thanks in advance and best regards,
Francesco
Old 15th October 2021, 06:06 PM   #495
I compiled it using a PeppyPlayer image on a rPi following this intructions:
Installation * project-owner/peppyalsa.doc Wiki * GitHub
I think it will work on other environments as well.
Old 15th October 2021, 10:48 PM   #496
Hi Tobias,
with the modification you have suggested, it seems that only the first 15 bars are active.
I am sorry to disturb you.
Greatings and thanks,
Francesco
Old 16th October 2021, 07:57 AM   #497
Hmmm, that‘s strange. For debugging purposes you can use
peppyalsa/ConsoleSpectrum.py at 822cee07b493f53fc9e687d5ee04345c41c1c85a * t0bit0bsen/peppyalsa * GitHub.
If you run the script via ssh, you can see the spectrum at the console. If the error is gone, you have to search the issue in your scripts. Otherwise you can try to build PeppyMeter from my fork and see what happens.
Old 16th October 2021, 08:40 PM   #498
Hi Tobias,
the problem was, most likely, related to the fact that I applied the change to the package downloaded directly from the PEPPYALSA GITHUB.
By downloading from your GITHUB and applying the change, both the "console spectrum" and my program work.
There is still a small area, larger in the linear case, that is not used because it is really outside the frequencies normally used in HiFi. For this, do you think a fixed frequency scale may be possible?
Thanks again and greetings,
Francesco
Old 17th October 2021, 09:45 AM   #499
Hi Francesco,
that's interesting. I have to check where the difference in both sources is.
If you don't like to see the upper most frequencies, you can simply request a spectrum with e.g. 31 bins and ignore the last value.
It is also possible to hard-code the frequencies in spectrum.c, if needed. All you need is to create fill
Code:
unsigned int bins[spectrum_size+1];
with the indices where your frequencies are. The index can can range from 0 to 256, where 0 is 0Hz and 256 is samplerate/2. The frequencies are equidistant distributed.
Kind regards
Tobias
Tobias
Old 17th October 2021, 06:50 PM   #500
Hi Tobias,
first of all thank you for your willingness to help me. Unfortunately I can't be that experienced to follow your guidance on how to modify "spectrum.c". What I would like to do is to have the following reference frequencies: 16; 20; 26; 32; 40; 51; 64; 81; 102; 128; 162; 204; 256; 324; 408; 512; 647; 816; 1024; 1294; 1632; 2048; 2589; 3264; 4096; 5178; 6528; 8192; 10355; 13056; 16384; 20710, possibly without any compensation (window) (note that trying "window 0 doesn't seem to work).
Please don't hesitate to let me know if I'm asking too much.
Francesco
PeppyMeterHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
