PC Based Computer music servers, crossovers, and equalization
PeppyMeter
PeppyMeter
Thread Tools
Old 5th August 2021, 01:50 AM   #471
rpi is offline rpi  United States
Yes, I'm planning to make a standalone spectrum analyzer - PeppySpectrum the same way as the PeppyMeter was made as a standalone program by minor refactoring of the Peppy Player VU Meter screensaver.
I was thinking about improving the spectrum analyzer UI but always found more interesting things to do
Best regards
Old 5th August 2021, 04:26 PM   #472
cheapvega is online now cheapvega  United States
Thanks! Looking forward to it
Old 7th August 2021, 07:23 AM   #473
fdealexa is offline fdealexa  Italy
Very good new, rpi.
Thanks a lot for all and best regards,
Francesco
Old 9th September 2021, 08:26 PM   #474
alexopth1512 is offline alexopth1512  Greece
Originally Posted by rpi View Post
Hi Francesco,
Very well done!
I'm planning to make new releases for the peppyalsa, PeppyMeter and Peppy Player. The release for the meter will include ability to define the meters which you want to show using comma separate string with meter names. Also I'll center the meter on screen if the screen resolution is larger than the meter resolution. I can also add the ability to call the external script when you touch the screen (in case of touchscreen). Do you think it can be helpful for switching screens?
Best regards
Hello, thank you so much for your efforts, it works good for me.
Sooo...
1. *PLEASE* make the touch screen to change meters,
2. Yes waiting for the analyzer too.
3. I use it as VUmeter to my DIY amps, using a USB audio card as input. I notice there is a small delay from actual music, I don't know if anything can be done.
Old 10th September 2021, 05:53 AM   #475
Good to know that you find it useful.
I'll try to implement a meter switching by touch in the next version. Though I'm not sure how to exit from meter in this case
Regarding a stand-alone Spectrum Analyzer, I'm not sure that that will happen this year. We will see...
Which display do you use for VU Meter? If that's a touchscreen with SPI interface then there can be delay between audio and meter. I didn't observe delays with HDMI touchscreens. Which software and USB card do you use?
Best regards
Old 10th September 2021, 06:54 AM   #476
Could exit be done with a hot key? <CTRL>-X or smth? Or double click?
Display is HDMI
I have tried 3 USB cards, one from official store and right now Icy Box. I don't use any other software only peppyalsa and peppymeter
Old 10th September 2021, 07:35 AM   #477
Do you use any software to play audio?
Old 10th September 2021, 08:05 AM   #478
Only aplay
Old 23rd September 2021, 07:40 PM   #479
chicks is offline chicks  United States
Playing with this on a Pi Zero with Hyperpixel 4" touchscreen.
It paints the meter backgrounds without issue, the pipe is working fine, but animations don't work, never see a needle or moving "lights" on the bars.
A print(r) statement in update_rectangle() method of component.py shows the data flowing through, but no animation:
pygame 2.0.1 (SDL 2.0.9, Python 3.7.3)
Hello from the pygame community. Contribute - pygame wiki
[2021-09-23 12:34:31,379] {datasource.py:102} DEBUG - opening pipe...
[2021-09-23 12:34:31,382] {datasource.py:124} DEBUG - starting data source...
[2021-09-23 12:34:31,397] {datasource.py:104} DEBUG - /home/pi/myfifo opened
[2021-09-23 12:34:31,406] {datasource.py:133} DEBUG - data source started
[2021-09-23 12:34:31,420] {peppymeter.py:106} DEBUG - PeppyMeter initialized
libpng warning: iCCP: known incorrect sRGB profile
<rect(143, 141, 256, 268)>
<rect(143, 108, 259, 301)>
<rect(184, 97, 220, 307)>
<rect(200, 80, 207, 323)>
<rect(233, 72, 176, 328)>
<rect(251, 58, 161, 342)>
Any suggestions?
Old 23rd September 2021, 08:04 PM   #480
I've never used Pygame 2 though I'm not sure if that can cause any issue as they promised that it will be backward compatible. Could you try to use the 'noise' data source to eliminate the pipe from the equation? For that set the 'type' to noise:
PeppyMeter/config.txt at 914ebcabe037df5854ad2ac0939084b816857c5b * project-owner/PeppyMeter * GitHub
Best regards
PeppyMeterHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
