PC Based Computer music servers, crossovers, and equalization
PeppyMeter
PeppyMeter
Thread Tools
Old 25th January 2021, 05:26 AM   #441
fdealexa is offline fdealexa  Italy
Hello Phofman, good morning.
I think that it is a very good idea.
I will test it today and I will report to you atout the results.
Thank you very much and best regards,
Francesco
Old 25th January 2021, 02:06 PM   #442
Hello Phofmann, hello "rpi", hello everybody,
thanks to all of you we got it.
Now i have to work to make it easy to install for all they would use it.
Thank you very much again for your help and best regards,
Francesco
Old 25th January 2021, 07:46 PM   #443
rpi is offline rpi  United States
Good to know that it works for Moode now.
Thanks a lot to phofman - our pathfinder in the jungle of the ALSA configuration
Old 25th January 2021, 08:48 PM   #444
Hello "rpi"
It's true: Phofmanhas has been very competent and very cooperative.
Of course thanks very much to you too!!!
Without the kind help from both of you, I were not able to make it happen.
Thanks again and best regards,
Francesco
Old 26th January 2021, 07:04 AM   #445
phofman is offline phofman  Czech Republic
I am glad the problem is solved. Useful to learn that the RPi headphone and HDMI alsa devices feature the hardware streams mixer.
Still I do not understand what made moode open the peppyalsa output device along with the "ALSA default" one while keeping the other devices intact. For that a full mpd.log would be needed to see all commands mpd received, not just the tail -f snippet.
Old 26th January 2021, 10:39 AM   #446
Thanks to you, Phofman, if it is running, now.
I will do that. In the mean time, if you like, try to see the playerlib.php.
Francesco
Old 26th January 2021, 03:13 PM   #447
Hello Phofman,
herewith enclosed, please find the last test for a system without DAC. Log was cleared before a restart, then a little of music, a long pause and then music again.
Please let me know if you would like similar log on a system with a DAC.
thanks and regards,
Francesco
File Type: zip peppyalsa - 06_no DAC - ALSA Through PEPPY - OK.zip (9.2 KB, 4 views)
Old 9th February 2021, 08:49 PM   #448
Hi everybody,
please note that the following post reports the status: of course about the second mentioned issue: could you be so kind to provide any suggestion?
128x64 OLED with Song Status and Spectrum Display on Raspberry Pi.
Thanks a lot again and best regards,
Francesco
Old 10th February 2021, 02:36 PM   #449
Hello "rpi", hello "phofman" and hello everyone,
this is to inform you that I have just created a thread in the moOde forum PeppyMeter and moOde where I mentioned your great help but obviously I didn't nominate you (for privacy).
Thanks again for putting up with me and supporting me.
Greetings,
Old 10th March 2021, 12:07 AM   #450
Hi all,
this is to inform you that as you can see in the attachement, I have added a two buttons to switch from moOde GUI to PeppyMeter and from PeppyMeter back to the moOde GUI.
Best regards and enjoy listening music... and its graphic,
Francesco
[PeppyMeter and moOde Video 2021-03-08.mp4 - Google Drive
PeppyMeterHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
