Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
PC Based Computer music servers, crossovers, and equalization |
Thread Tools |
#431 |
Hi Phofman, hi ALL,
I confirm that the log is in verbose mode. As mentioned I had built a system, without any additional DAC board, from scratch and tested it in the following modes: 01. without peppyalsa. the sound very good 02. with peppyalsa: slave on hw:0,0. Peppyalsa is ok, but the sound is not good 03. with peppyalsa: slave on null. Peppyalsa is not ok, the sound is very good. I did all the tests modifying the mpd.conf manually and restarting MPD only. Tomorrow I will do the same tests with the system with the additional DAC board. Regards and thanks, Francesco |
#432 |
There must be something else going on in the configuration.
Let's talk about 02. The config has all alsa outputs, yet mpd.log shows using/opening only: Code:
Jan 21 21:03 : output: opened "ALSA default" (alsa) audio_format=44100:16:2 Jan 21 21:03 : output: opened "peppyalsa" (alsa) audio_format=44100:24:2 Code:
Jan 18 23:58 : output: opened "ALSA default" (alsa) audio_format=44100:16:2 Jan 18 23:58 : output: opened "peppyalsa" (alsa) audio_format=44100:24:2 Jan 18 23:58 : output: opened "ALSA crossfeed" (alsa) audio_format=44100:24:2 Jan 18 23:58 : output: opened "ALSA parametric eq" (alsa) audio_format=44100:24:2 Jan 18 23:58 : output: opened "ALSA graphic eq" (alsa) audio_format=44100:24:2 Jan 18 23:58 : output: opened "ALSA polarity inversion" (alsa) audio_format=44100:16:2 |
#433 |
Hi Phofman,
I built those 3 new tests to have a clean situation. Previous configurations may have been generated from strange and layered tests. If you need I can try to reproduce it, I have the relative SD. I don't know why all the "alsa" were opened. Those "alsa" are related to some functions available on the moOde GUI that I have never enabled. I would like, today, if you have no other urgent requests, simulate tests 02 and 03 on the configuration with the additional DAC, to see if "device busy" appears again, that means two different behaviors. Have a nice day and thank you, Francesco |
#434 |
Hi Phofman,
As scheduled, I built these 3 new tests (as for the configuration without the DAC board) with the additional DAC board,to have a clean situation. Unfortunately, but as expected, the "device busy" appears again, so the big difference is that without the DAC we can configure and send data to the HW:0,0, that seems to be impossible with the additional DAC board. I confirm that with a "null" as a slave, peppy alsa opens the fifo file but does not send data. Thank you and best regards, Francesco |
#435 |
Hello Phofman and hello to everybody,
I did the same tests already done on a system without "any DAC" board and on another system with the "AUDIOPHONICS DAC", on another system with an "ALLO DAC" and the results are the same. Please find attached the results of these last tests. would you please be so kind to help me with any other suggestion? Thanks and best regards, Francesco |
#436 |
There is no reason a different sound device with a single substream (incapable of stream mixing) should behave differently.
I keep repeating my question with no answer: why does mpd not try to open the invpolarity device, while it does try to open peppyalsa? Why is MPD handling these two devices differently? There must be something else controlling which devices are used and which are ignored. Nevertheless, why can't you remove the ALSA default device from MPD config and play through the peppyalsa device which should be passing samples to hw:0 (being its slave)? |
Thread Tools | |
New To Site? | Need Help? |
