Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
PC Based Computer music servers, crossovers, and equalization |
Thread Tools |
#351 |
The difference is access permissions. Your alsa process runs under the mpd user, yet the fifos are in home dirs of other users. How about trying to configure them into a directory which all users can access, e.g. /tmp, would it help?
#352 |
Now I have understood, I guess that's what also the mpd oled was adding the fifo part in the mpd conf directly as tmp folder.. To be accessible mpd user.. But if I know how to do it... Or will be great but like I said I am not experienced user. Thanks a lot for finding the root cause of the issue |
#353 |
Fifos need two processes - one creates it and writes into it, another reads from it. When placing fifos into /tmp (where every user can write files - look at output of command ls -ld /tmp ) and creating them with appropriate permissions (e.g. everyone read), the communication can be established.
The creating/writing process is configured in the alsa config. I guess the peppy meter is configured in PeppyMeter/config.txt at master * project-owner/PeppyMeter * GitHub . |
#354 |
1. I will create the fifo in /tmp then assign 755 permission 2. Set path to new fifo file in config. Txt 3. Change also the new fifo path in asound.conf 4. That's it?. Thanks |
#355 |
Maybe the peppyalsa plugin creates the FIFO itself, I have not checked.
Just try and see, eventual errors/problems can always be fixed. |
#356 |
In order to create the fifo I need to create it in home volumio with mkfifo myfifo so I guess does not creating. I will do it and announce.
Thanks |
#357 |
Hello my dear friends ,
I am so glad that the peppymeter plugin is fully working on my setup . Like phoman pointed out and the end it was problem of integration fifo with mpd . I have perfomed exactly the steps that you sugested and it working . I am so glat that it is working . Maybe this great plugin can be updated for Volumio OS PS: now remain only the issue with hanging the pepymeter picture when killing the peppymeter process. It does not switching to Volumio UI just show the meter picture My best regards . Florin Last edited by lintbf; 30th November 2020 at 10:46 AM. |
#358 |
Congrats for making it work by yourself.
#359 |
Without your help and rpi I could not make . but I learn
If I change the meter type it shoukd work by default no ? For example changing from vintage to blue Thanks |
#360 |
Something is weird. Aftert a restar the vumeter is not working
Thread Tools | |
New To Site? | Need Help? |
