PC Based Computer music servers, crossovers, and equalization
Chromecast audio
Chromecast audio
Old 20th January 2019, 08:47 AM   #121
Speedysteve7 is offline Speedysteve7  United Kingdom
Speedysteve7's Avatar
Originally Posted by jimk04 View Post
Not wanting to spoil the CCA thread but I came here having being disheartened with Rpi with Volumio. Spent a testing afternoon today loading Moode and it seems to work, albeit I keep getting a crackly static noise.
But after all the effort....not sure it's good enough to warrant over a CCA.
Full disclosure.....CCA into a stock Cambridge DAC magic.....Rpi with a berry dac+ pro
I am still a CCA proponent!
Berry DAC+ pro is what's holding you back there I think.
Need a Allo Digione or Signature to step up a level.
Old 20th January 2019, 11:17 AM   #122
Yatsushiro is offline Yatsushiro  France
Even with a Berry DAC+, there should not be a crackly static noise. I would suggest persevering with your RPi over the CCA.
To try and identify the source of your static, I'd try removing your DAC, and using the RPi 3.5mm jack. If the static disappears, then the problem is with the DAC. IIRC, there may be some issues with some of the HiFiBerry drivers, so may be worth experimenting.
If your RPI proves to be static free, I'd suggest an Allo Boss 1.2, as this is a relatively cheap upgrade, compared to the Digione. I'd expect an RPi/Boss combination to be noticeably better than the CCA, unless there is something unusual downstream (preamp, amp etc)
Last edited by Yatsushiro; 20th January 2019 at 11:23 AM. Reason: Fat Finger Spelling
Old 20th January 2019, 11:29 AM   #123
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
If the CCA is connected to a DAC, won't that define the quality?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 20th January 2019, 02:42 PM   #124
audiobomber is offline audiobomber  Canada
audiobomber's Avatar
Not completely:
1. CCA jitter worsens as resolution goes up, and gets quite ugly at 96/24
2. Optical connection is compromised vs. USB or I2S
IME, the RPI 3 B+ sounds better into the same DAC (iFi Audio nano iOne), as long as you don't power the DAC from the RPI USB port.
The considerably more expensive sms-200 sounds much better than CCA, both streaming into my Audiolab 8200CD.
Dan
Old 3rd February 2019, 03:58 PM   #125
jimk04 is offline jimk04  United Kingdom
Can't seem to get 24bit/96 out of the CCA via optical I to my DAC. Streamer is doing it's thing to the CCA but there it all goes quiet.
I thought it support3s 24bit
Chromecast audioHide this!Advertise here!
Audio Amateur, Glass Audio, Speaker Builder - full sets available Cognition Swap Meet 3 26th February 2015 08:37 PM
Google Chromecast PedroDaGr8 The Lounge 1 7th August 2013 12:02 PM
Pacific Northwest Audio Society - April 11th - First Sound Audio fork Clubs & Events 0 7th April 2013 12:36 AM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
Copyright ©1999-2019 diyAudio
