PC Based Computer music servers, crossovers, and equalization
piCorePlayer = piCore Linux + Raspberry Pi + Squeezelite
Old 29th September 2019, 11:08 AM   #361
soundcheck is offline soundcheck  Germany
It's not about 64bit audio data playback.
It's about 64bit processing. That's a different subject.
Things can and many get more efficient. From what I read 20-30% performance gain in certain areas can be expected.
Considering the extremely poor RPI performance on e.g. HQ resampling. I'd very well appreciate such a boost.
I'll run the benchmarks if I'm done with it.
And it's not that there are no full (kernel and userspace) 64bit RPI OSes around. Actually they are around for quite a while.
The issue was the mainlinekernel and Uboot on these 64bit systems.
The PI without the PI kernel IMO looses it's key selling point. Since Pi4 the RPI folks concentrate much more on the 64-bit PI kernel.
That changes the game.
Old 30th September 2019, 03:44 AM   #362
Greg Stewart is offline Greg Stewart  United States
I want to say thanks to the PcP team for their support in getting my USBBridge Signatures up on PcP the last several days. I'm big into small op systems and player footprints and PcP fits that perfectly. AND they have made getting this running on their new Beta a pleasure!
THANKS ALL!
Greg in Mississippi
P.S. See my posts #588 & #594 in Allo's Shanti / USBBridge Sig thread:
Shanti Dual LPS 5V/3A , 5V/1.5A
Basically, the USBBridge Signature used as an RPi-substitute I2S source is STUNNING. Definitely as large of a step above my linear-regulated-modified RPi 2B as they were above a stock RPi. HIGHLY RECOMMENDED!
Everything matters!
Old 30th September 2019, 08:21 AM   #363
Dear Greg.
If you'd like to promote/introduce that product I'd really appreciate if you'd open a new thread.
I'd love to comment. I'd give my 2cts why people better think twice to go for such a product!
Wow. Didn't realize you switched sides. Now you're also BIG on the software side. That's good. We all know that only SW AND HW makes a solution.
Perhaps you could share your experiences on that SW side in another thread! Looking forward to it.
Great to have you around.
Old 10th October 2019, 02:40 PM   #364
Just FYI - since we've been discussing it recently.
I finally manged to build a complete 64bit ArchLinux installation - kernel & userland.
Code:
root@boss64:~# uname -a
Linux boss64 4.19.76-rt25-sc1 #1 SMP PREEMPT RT Sun Oct 6 14:11:00 CEST 2019 aarch64 GNU/Linux
root@boss64:~# file /usr/bin/ls
/usr/bin/ls: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=d3d0049a9af71d4be7a4dafff7d668b248b75319, for GNU/Linux 3.7.0, stripped
Not that many 64bit RPI OSes (with RPI kernel!) around.
Note:
The RPI kernel is prerequisite to get our beloved audio HATs going.
Since most 64bit systems come with the mainline kernel most audio devices
and a lot of other things wouldn't be working anymore. The RPI kernel
is a must and it's gonna be that way for quite a while.
Let see if Paul (and TinyCore) can catch up with a 64bit userland sooner or later.
Enjoy.
Old 11th October 2019, 12:14 AM   #365
paul123 is offline paul123
paul123's Avatar
Have you had the chance to do any 32/64 bit benchmarking? Then of course does it make any real audible changes? Curious if the effort is really worth it.
Old 11th October 2019, 07:59 AM   #366
Not yet. I'm still in the process to analyze and understand the situation. You know that the devil lies in the details.
For sure it's more then just a simple swap. And there's not much info around. Lot's off digging.
E.g.
* rewriting/updating all my scripts
* gcc CFLAGS are different
* I tried to compile flac/libflac and I'm not sure yet if and how NASM works on 64bit ARM.
* and then ArchLinux doesn't offer a 64-bit userland for PI-4.
I think you'd do good to not waste too much time on it for know.
You'd obviously would have to provide a separate 64bit image, just for PI3/4. Not sure if you really want to go down that road.
Your 64bit kernel und 32bit userland is a stable and extremely well working solution. IMO no need to step up in the near future.
Old 19th October 2019, 01:37 PM   #367
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Sorry, I lost track of the conversations over here......did you get your NFS problem sorted.
More than likely you are missing a mount option "vers=x" (Where x = 3 or possibly 2) it depends on what you are trying to connect to.
No, Iíve given up. Using a usb drive instead of network now.
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
piCorePlayer = piCore Linux + Raspberry Pi + SqueezeliteHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Another Raspberry Pi Radio rpi PC Based 17 17th June 2015 03:29 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Raspberry Pi & accessories Nikitas Swap Meet 5 5th July 2013 12:47 PM
Copyright ©1999-2019 diyAudio
